The Ryobi Tool Appreciation/Review Permathread!
rick carpenter
Huntsville, East Texas
I bit on this deal (was $109 when i ordered $139 now) and it arrived yesterday. I was impressed by its torque...it easily and quickly removed the lug nuts on everything i could test it on including some i Torq'd as tight as i could without worrying about snapping the stud. However it had an intertermittant problem on the 3rd speed, it would take a few trigger pulls to get it to start. HD is shipping a new one and picking this one up. I hope the new ones better because it was really a nice tool...We'll see. If still an issue i'll probably go yellow because i already have a 5AH batttery with my weed wacker.
JG
I have the 1/2" and 3/8" impact wrenches. I find them very useful for construction driving lags or using bit sockets, especially the 3/8". Haven't had to take off wheels yet with the 1/2"
dagofast
The QC in AZ
This comes as a kit with a charger and 4.0AH battery,so two different units and two different batteries.
That is really weird. No wonder you are frustrated. I wonder if there has been a change in the product? Mine works flawlessly but it is over 18 months old now.
jg4660
Western NY
I'm gonna email Ryobi and see if i get a response anyway...i'll likely use it infrequently so its probably okay the way it is. I don't plan on using it enough to justify a red one at almost 2x the money.
Thanks
Jeff
MileHighRover
Has anyone used the angle grinder included in the current Ryobi Days deal, the P421? Looks like the grinder alone can be had for 45 bucks and the reviews seem mostly positive. My grinding needs are pretty light and pretty rare, but needing to grind and not being able to grind is never fun.
Just got that on the free tool deal. Used it a couple times. Two days ago I used it with a wire wheel to clean up some steel pipe. Today I used it with a diamond concrete cutter to prepare about 25 feet of cracks in my driveway for crack sealer. I love it. It'll do everything I'm going to ask of it. I'm going to pick up another one.
B T C
Mid Michigan via Kentucky, Georgia and Tennessee
Thanks for the insight. I have a few things, very few actually, that I need to grind down, and I could probably use a file, but I also live on a private cul-de-sac and we're contemplating how we are going to address some cracks in the asphalt without paying through the nose for a professional. I hadn't even considered that an angle grinder could potentially be used in that scenario.
BioNerd
Undisclosed location in the middle of nowhere
I have been using 23g and 18g cordless nailers and they are very good.
The 15g angled nailer is a POS.
My whole company was smirking at them been ryobi but they have all borrowed them at some point.
Thumbs up to these guns (23 and 18)
Sent from my LM-X212(G) using Tapatalk
MileHighRover
Angle grinders are very versatile. I use mine with grinder wheels, flap discs for sanding and grinding, cut off wheels, wire wheels and now the diamond cut off wheel. Many people have multiple angle grinders set up for each specific use so they don't have to change out the wheels. That's why I'll pick up another one. That'll give me 3 for now.
gazza
Melbourne Aust
Anyone have experience with the 18 volt chain saw or pole saw? Have lots of other 18 volt tools I’m fond of, need something for light work around the yard.
Sent from my iPad using The Garage Journal mobile app
A bit of a late response to this question, the chain speed on any chainsaw makes all the difference, non brushless 18v Ryobi saws are too slow to work efficiently.
The new Ryobi 18v brushless chain saw, first use. Nice and light, thin chain cut, and its quick and easy to use. Largest of the dead wattle about 6" or 150mm thick cut thru in about 14 seconds. All this cutting with a 5 amp hour battery used about 1 bar/light on the battery (1/4) Very happy over all.
Henricogolfer
Henrico, VA
No worries, not in a hurry and looking for a sale! Thanks for the feedback.
Handyandy23
Ontario, Canada
Just picked up this little guy today. Can't believe I went this long without a small cordless shop vac! What a useful tool. Most of my messes are smaller, just cleaning up a mess from a single job, and pulling out the full size shop vac is always a pain.
This thing actually has quite a bit of suction. Smaller hose to achieve it, but picks up stuff well. I think it was rated / tested at 45 CFM, same as the M18 version. I was going to get the DeWalt version since I have more yellow batteries, but it only makes 34 CFM. Glad I went green with this one.
jrbab
I have one also - very handy. Thought about the 6 gallon one but that sort of defeated the
purpose of a quick portable unit. Great unit and easy to use. I agree I wish it had a longer hose but it does the job well.
64merc
Texas
Yeah, not sure how I survived without that cordless shop vac! Very handy!
I agree though, that darn hose is about a foot too short. You have to bring it up pretty close to where you are working. For instance, if you are vacuuming a trunk, you have to put it in the trunk or just rest it on the edge while you hold onto it.
Handyandy23
Ontario, Canada
I haven't used it enough yet to have a strong opinion on the hose, but I do really like that it's "stretchy". Stores onboard nice and compact, but stretches out fairly well.
And I agree on the 6 gallon one - the 3 gallon is the perfect size to be convenient and easy to grab for a couple saw cuts or a small mess. I'm guessing my full size one won't move very much anymore.
cderalow
Potomac, MD
My 2nd season using a Ryobi 40V string trimmer. Not a happy camper. Doesn't have the line speed of a gas model, thus limited to grass & dandelions. Its actually heavier than my Stihl. You constantly have to feed out line to max to be effective. The battery/ charger is failing. Just sits there w/ a red light. Calling customer service was an exercise in futility. They never pick up nor return the call. Out of frustration I slammed the battery home into the charger. Works now! For how long i don't know.
If you’re on Facebook reach out to them via messenger.
Their CS team there has been great for me. Their phone service not so much since quarantine started.
jgromada
Maryland (between DC & Balt)
i got this earlier on sale from Direct Tools Outlet, refurb but looks new and works quite well . 24 in bar on the hedge trimmer
cderalow
Potomac, MD
I snagged the 18V equivalent out of ryobi days for free with some 4ah batteries.
Even the 22” 18V version is a beast and a significant improvement over old school corded.
mv213
Dallas, OR (the OTHER "Big D")
Ryobi email-“A new revolution coming August 2020”
I got this email from Ryobi a couple days ago....any good ideas what it could be?
I’d like to see some high draw tools like miter saws or compressors that can take 2 batteries. No clue what it really is. This is from my iPad and Gmail so cant show the whole email.
moab11
Thunder Bay, Ontario
my guess is Gen 2 Brushless tools. From the different teasers that they have, it seems to show the impact/drill/sawzall/circular saws. I don't think it will be anything too new, just updated brushless tools, probably better able to use the HP+ batteries.
setfocus
rust belt
saw an ad on my facebook feed for 3/8 ryobi ratchet, I don't have any ryobi but if I did? I might get one if priced right, when it starts selling... but I already started to commit to milwaukee and they have a ratchet
https://toolcraze.net/ryobi-18v-3-8-4-position-ratchet-p344/
https://www.ryobitools.com/products/details/18v-38-in-ratchet
feel like stanley/black&decker would make money if they made a yellow version of the mac ratchet. Tool truck prices on cordless powertools are stupid. Only reason I have a snap-on ct4410 3/8 impact is because I got it half price, through the student program years ago
mv213
After watching the video in the link I think you are probably right. :)
jblnut
In the Middle of MN
Anyone have the floor sweeper ? I have a ton of Ryobi stuff already and it seems like it would be a good deal to keep the shop floor clean.
mv213
@moab11, you were right. The new tools were announced today. Interesting looking high speed mini saw for tile metal. I am FOR SURE getting the new 2-speed right angle drill, been waiting forever for one. I’ll also get the 1/2” drill-driver and maybe the mini high speed cutter. https://www.ryobitools.com/hp
CKS1955
Does anyone have any experience with the Ryobi 6-Port Supercharger P135? I purchased mine on June 23 and around July 15 the port identified as #1 stopped working. The other 5 ports are still good. I’m just curious if this is a one off problem or if these have continuous issues like the P117 before I decide to either get a replacement or just return it.
Thanks,
Jay
340wedge
I went to DirectTools looking for the new 3/8 battery powered ratchet but they didn't have one in stock. They do have a huge shipment coming in Monday so I will check back, but the trip wasn't a total waste. They had a huge box with empty bags, I got two bags for $5.00!
rick carpenter
I wish TTI made some plain blow-mold or other hard sided tool boxes for their Ryobi (and Milwaukee) cordless tools. Til then Plano or other 'ammo can' types boxes will have to suffice for me.
Bacon!
I have a nice blow molded case for my ancient Dewalt drill, that I immediately chucked under a storage bench and haven't used it once because it can only hold the drill.
Ammo cans are far better, can hold 2 (depending on what they are) tools and bits/blades/sockets/etc for them. I can even shoehorn the charger in if I pack it carefully. I put them in a plastic paint ball ammo box which unlike the metal ones, also has small compartment hatches on top of the lid.
moab11
Haha, even a blind monkey gets it right once in a while!
I'll have to take a closer look at the new offerings, but nothing really stood out to me as a must buy. The smaller heads on the tools is nice, but the large battery is still a limit. My M12 drill/impact fill that void nicely.
mv213
I’ve been hoping for a 2-speed right angle drill for years....the old one just doesn’t have the low speed torque and control for driving tough screws in tight spots. Pretty happy it’s coming out.
webscrounger
Midwest
I got two of them on sale last year. Work great. Couldn't be happier with the purchase.
I should mention that one P721 has one large square LED light source and the slightly newer one has a smaller round LED light source. Both are rated the same and appear to put out an equal amount of light. I don't know the difference between the LEDs and don't know where to find the specs on either but both are good AFAIC.
ThatSickRip
Im a Milwaukee guy, but Direct Tools has some good deals today and free shipping on some Ryobi stuff that I need for some home projects, but I cant justify the Milwaukee price tag for some of these items. Any feedback from you guys besides what I find on the HD site?
23g pin nailer P318
18g brad nailer P320
Speed saw rotary cutter P531
7 1/4 miter saw TS1144 (was going to use for small size and small baseboard/moulding work so I dont have to drag the larger 10" out)
3/8 crown stapler P317
12" chainsaw kit P549
webscrounger
Midwest
Same as you TSR. Milwaukee guy primarily. But, I have many Ryobi One+ tools and accessories that I think are excellent and may be a better price/performance deal than some other brands. Though my hardest working tools (drills, saws, impact drivers/wrenches, ets) are older corded Milwaukee Magnum/Heavy Duty with dups in newer cordless Fuel m12 & M18 tools.
I also just picked up the Ryobi 18ga brad nailer and 3/8 crown stapler. Couldn’t pass them up for the price. Reviews are good too.
ThatSickRip
Same, all my drills/impacts/lights/circular saws are Red, and Ive got 1 16g nailer that was a smoking deal 2 years ago, but cant justify the $279 for the M18 brad when I can get the Ryobi 18g, 23g, stapler and rotary tool for less than the M18 (for my usage anyway).
Did you get the 18g and stapler from DT also?
webscrounger
Midwest
I got them from HD when they went on Black Friday sales. Bought some new Fuel stuff too. My CC is screaming right now!
AceofSpad3s
I've been asleep for years and only noticed the new offerings now. How are those new compact 18 volt tools?
AceofSpad3s
Don't intend on buying anything at the moment, but the impact and drill combo is what interests me because of the size while staying in a full sized battery.
