SuperSonic
- Joined
- Sep 1, 2014
- Messages
- 22
Now just hear me out for a second.
I missed out on a mini split deal so I ended up buying a 5 ton r22 condenser for a song. It came with a matching coil. Now I found a 410a air handler for cheap too.
I know you can’t use the two together, but does an air handler being 410a just refer to the coil that’s in it and I can use the r22 coil with it instead and be just fine?
I don’t know enough about AC systems to understand this.
Also, I bought a 5 ton unit, but finding used 5 ton air handlers is proving difficult so would I be fine using a 4 ton or 3 ton, since that is the most cooling I need?
Thank you all.
Thank you all.
