Backyard Buddy Hydraulics
Jeffreylmarshall
Covington, LA
I am new to lifts and when lowering my lift the hyrdraulic fluid tank begins to leak around the cap then blows the cap off sending fluid about twenty feet!
Have I simply overfilled the resovoir? No instructions regarding the pump, etc
Lucid Moments
Gainesville, Ga
I am certainly not an expert but it sounds to me like you overfilled it. With the lift on the floor the fluid should be an inch or two below the top at least.
mark#3
Yes, you don't fill it with the apparatus extended, you check it with everything retracted
sweetk30
finger lakes area upstate ,ny
lift on ground or rams in closed position . then fill to around 3/4 capacity .
if new install run up and down 5-6 times but with breaks between lifts to let the air settle out of the fluid . as you dont want to **** air filled fluid back in you just pumped out in to the holding tank .
tuttebenne
Yes sounds overfilled. Check reservoir with ramps/lift on the ground. Cylinder is filled with fluid when lift is at its highest position and ram is fully retracted into the bore of the cylinder.
Pen & Wrench
Huron, SD
I will say this: From time to time I rent a local dump trailer, and I have the same experience when I let the box down from fully extended. When I mentioned it, they said to let it down and stop from time to time to slow the hoist retraction process. Hydraulic fluid level was at the recommended level before all this happened for me. I believe it is a design flaw by many to provide the absolute minimum to make it work. If I had a choice I'd make sure there is enough hydraulic fluid, and then if necessary, units like that and like the dump trailer I rent from time to time, should have been designed with a larger reservoir to handle the flow of hydraulic fluid without running over when the cylinder retracts quickly.
FredWanaker
NorCal
Don't know but hydraulic fluid shouldn't do that unless the reservoir is too full, or air is trapped in the system and it is the air blowing out creating the mess.
tuttebenne
Yes. If somehow air is not vented from the cylinder as the piston is moving and it is carried along with the fluid on its journey back into the reservoir, it is like 10lbs of ... candy in a 5 lb bag.
finn
The UP, God's country
A hydraulic system would have an orifice in the return to control the retraction speed of the cylinder when the lift or dump bed is being lowered. If the orifice is too large, descent rate has to be controlled by feathering the valve, which is less than ideal.
A reservoir is sized to contain enough fluid to fully extend the Rams. Additional fluid beyond that serves no purpose, other than perhaps giving a little buffer to provide a margin if there are minor leaks.
You may want to look into the quality of the hydraulic fluid you are using. Foaming is a possible issue with low quality fluid. Foam takes up reservoir volume with aerated fluid, which takes more room.
I think others have called it correctly. Overfilling or plugged air vents, although a plugged vent might just result in a ballooned tank..
These are pretty simple systems. Pump, reservoir, relief valve, control valve, orifice, hoses, and ram.
