Show your new tool arrivals
Jarhead0408
Who knows?
Got a new wheel balancer for home use.
Its an Atlas WB-HS.
The repeatability of this unit has been amazing; removing, spinning and remounting provides the same results time and again, which is my books is the ultimate measure of greatness for a balancer.
Very nice! Source?
Qualitytools
SOCAL
Its an Atlas WB-HS.
Nice! Is that a white e30 with BBS wheels in the background?
Qualitytools
SOCAL
Not sure if it is a limited run set, but it is called "A Round of Screwdrivers" (Google and you'll find a lot of links).
Comes with bottle opener, sticker pack, coffee cup coasters and the round metal case. The holders for the screwdriver are cardboard so I won't keep the screwdrivers in there (they so pretty they going on the peg board lol). I'll use the case for a spare parts holder or something.
Used the flat head already for an easy Harley job. Quite happy.
Thanks for the info, enjoy!
noid
Yup!
Very nice! Source?
Got it new locally (canada) from some smaller outfit. In the US I think you can get them from Greg Smith equipment, if not google should bring up a few alternative places.
The hand spin unit has the same brain as the motorized models, so unless youre spining a ton a wheels I recommend getting the hand spin model.
darkzero
SoCal
What didn’t you like about it?
The frame had casting defects which made it look ugly. Looked like it was ground down on one area. Thimble was also very tight. I probably could have adjusted the spindle threads if I wasn't going to return.
DuratecMan10
Central Florida
New to me pressure washer I got from the curb. Pump and motor work great, just needs a new hose and gun.
javyLSU
New Haven, CT
Little green, little red, little chrome...
The green: Rechargeable neck light (ECHDC038G) digital LCD circuit tester (EECT400-TG) and Instinct-handled soft grip trim tool (ASG186BG).
The red: Magnetic headlamp (ASG186BG) and extendable shank bit driver set (SGDQ16KT).
The chrome: 12 pt. zero offset box wrenches in 14/17mm (XDHFM1417) and 3/8 / 7/16 (XDHF1214).
Odd-job
Some cross threading oopsies sometimes happen around my old house and equipment so finally invested in an Irwin SAE Tap and Die set to try to save me a trip to the hardware store since this pandemic seems to keep going. Bought on Amazon Warehouse for $70. Looks like Irwin started going cheap on the cases. Pic versus my older metric set below.
kudakev615
loved the SO neck light so much i bought second one recently. is use it around my head at the temples. i do a lot of interior work such as sunroofs and dash work and i cant work with out one. unfortunately it only last about 2 hrs on high so thats the reason for buying a second one
sweet victory
USA
I got the new Snap On straight die grinder today. I think I prefer the right angle Milwaukee, but the straight Snap On. I love the fact this comes with a 1/4" and 1/8" collet, so this can be used as a dremel on steroids! I use my milwaukee dremel regularly to trim my dog's nails, and the Milwaukee has been getting louder and louder lately. I'm sure the pup will appreciate how quiet this thing is.
Skin
Boston
I saw the right angle. It looks crazy long. Am I also right in that it has an on switch and a wheel on a potentiometer controlling RPM like a cordless Dremel?
Not a fan of that since you cant vary RPM as you move along a surface by adjusting hand pressure. Also going to cause problems if you snag something like a rag. With a normal die grinder you just let go. With that thing you're going to flail around like an idiot for a good 5 seconds trying to shut it off as bits of rag go everywhere.
Not quite sure what they were thinking there. The trigger paddle off the right angle drill would of been ideal.
designer485
Orange County, CA
DeWalt 20v Inflator. I have had my eye on this one for a while and finally pulled the trigger. Very happy that I did, this thing is great. Dial in your pressure, press go and walk away. Come back when it turns off. It is not super fast, but I think it is quick enough to be impressive.
sweet victory
USA
Yes, the right angle has the potentiometer style selector switch and on/off switch. It's indeed much much longer. I agree with you 100% with the right angle and paddle switch, which I why I have the Milwaukee for that one. Since I plan on holding this style of die grinder like I would a pencil, the on/off switch is going to be more ergonomic. Best of both worlds. :bounce:
Jarhead0408
Who knows?
Yup!
Gotcha. Thanks!
ptgarcia
Alta Loma, CA
I have the Ryobi of the same basic design and love it. Has come in very handy in the short time I've owned it.
X1 Mike
Flagler, Fl
I added a couple the past two days. Capri Tools 1/4” drive long and short hex sockets. 2mm -6mm short and 4-6mm long. I have better sockets as my go-to’s but I am impressed with these so far.
Next is a 1/4” drive Snap-Op ratchet. I primarily use Matco for ratchets but I got the 1/2” version and liked it enough to add this one. Hundred bucks tax included off the truck today.
Snapped-off
Indiana
Extra long Gearwrench pliers
19" Williams handle for my 3/4" Snap-on ratchet head
1/8" Williams combo wrench
NOS FK936
javyLSU
New Haven, CT
New Mac dealer showed up with my order (and no A/C in the truck!!)
123 pc ratcheting hex bit driver set (SBDR123SA)
2 pc straight screwdriver/pry bar set (PBS2G)
NKlamerus
Springfield, Or. (From Florida)
Absolutely love mine! I was prepared to get the Ryobi model but got one of these for 70$
I leave it in the truck, definitely beats the air compressor
The low pressure side kinda *****, I prefer the leaf blower with a funnel
Sent from my SM-N975U using Tapatalk
1320
Arizona
New to me Hein-Werner 10 ton floor jack. It's wheels are wide enough that I can roll it across my gravel with no problem.
16again
Boynton Beach, FL.
Not a tool, BUT it will be a work bench! 21603b9daa9af6e98beb86c6354cbefe.jpg48f7046d6d37cd7c3429df9b50616d57.jpg
tig
Durango, CO
I have the Carlyle-branded version of those pistol-grip strippers - I absolutely LOVE them, they are my favorites for automotive wiring.
3357647
Yours look a little nicer with the comfort grip, nice grab.
Since I've been exposed to the below, I've pushed all traditional wire strippers to the back of my drawer. Once you go with one of these, you won't go back:
Legion Prime
Leelenau County MI
Not a tool, BUT it will be a work bench!l
Instant workbench! Just add the bench, and you know . . . the work! :lol:
All I've got is a tape measure, I like it so far. The light is actually bright enough to use as a field expedient flashlight if it comes to that. It costs the same as I paid for my Milwaukee and the lock doesn't take quite so much pressure to operate. I'd say it's a keeper, even came with it's own charge cable.
javyLSU
New Haven, CT
I'm interested to hear more about your experience with these. I was dead set on picking a pair up a few months ago, but kept thinking of the horrible experience I had with the Irwin automatic strippers. These are different, so I'm interested to know if these are any better.
wolverinehusky
Seattle (don't move here we full)
CDI 3/8 Digital Torque Wrench. I have the 1/4" CDI, and decided to get rid of the crappy Kobalt 3/8. I didn't quite trust the Kobalt, and the Kobalt lacks flex head, but most importantly, it doesn't tell you the high torque value attained, which was a pain in the ****. The CDI has the flex head and provides highest torque value, so gonna make my life sooooo much easier.
The Gearwrench ratcheting stubbies are cool, but they came in pretty beat up. They were moving around in the packaging, and I wouldn't be surprised if they were restocked used as they had some scuff marks on them (AMZN order). Cheap so not gonna return they'll do the job.
tig
Durango, CO
I just bought a 2nd pair and grinned as I played with them thinking "Man, it's nice to actually get a quality feeling tool on amazon.com every once and a while."
