is there a panel size chart anywhere?
jdsac
Object- replace zinsco 200 amp with something else, but if possible, I would like to replace it with something physically similar- ie meter position etc.
looking for a dimension chart- is there any?
thanks!
Norcal
thanks!
Not going to be easy, and depending on the Zinsco panel may be impossible. You have not given a location If a panel has to meet EUSERC standards will come ito play too. Could use a Zinsco II panel, AKA Eaton BR, Only way find out what is close would be to go to the 4 manufacturers website & look the data.
GE: https://electrification.us.abb.com/products/load-centers/powermark-gold-meter-socket
Eaton: https://www.eaton.com/us/en-us/prod...al-metering-selector-tool/meter-breakers.html
Siemens: https://www.sea.siemens.com/ Firefox would not let me go further.
Square D: https://www.se.com/us/en/product-ra...ter=business-5-residential-and-small-business
Stuart in MN
Minneapolis
thanks!
Are you saying it's a combination panel with the meter built in? If so I assume it's mounted on the exterior? How many circuits?
yatg
Southern Oregon
Check with your power company and get a list of approved meter mains. Then you can look those up. Most major manufacturers have dimensional drawings.
  • PWFDS-SYRS-0043.pdf
Norcal
The OP has a Zinsco panel & some of their designs were quite unusual, which makes replacement more difficult.
sberry
Brethren, Michigan
Yes, I had an old CH was narrow, what a pain. I would do it slightly different if I were to do it again under different circumstances.
J
jdsac
Surface mount on wood siding, not recessed if that helps- thanks again
Norcal
Photos will help as a picture being worth a thousand words still applies, but being surface mount will make things easier.
J
jdsac
Sorry about leaving out the details- it's a zinsco overhead feed 200 amp panel in California if that helps- thanks again
Norcal
Can you post a photo? There are two different types that I can think of and the oddest type is the most likely.
