So some crazy old guy who is attached to a rusty high mileage '93 fleetwood caddy had me do brake and suspension work (leaking brake line) that probably cost around what the thing is worth
so he drives away and the serp belt shreds, was fine when I test drove it. Check the pulleys, good. Put a new belt on and it jumps half off. Whole alternator and power steering pump bracket is wobbling around can see it's broke off at the bolt ears... finally get the new one from ebay (no one makes that **** anymore) and tear it down.
2 bolts were broken off in the cyl head. Probably about 3/8ish diameter, bolt head was I think next size up from 7/16? something standard that was little smaller than 15mm, one broke flush and the other is recessed. The bolts aren't that long and couldn't tread too deep
what's the best extractor set that isn't rediculous in price, that I can have, in hand, monday. Mac and Matco stop by on monday also. I want this thing out of my bay and my life, any other tricks, would a little heat be ok, left hand drill bits? welding isn't an option. Think it's just a TBI 350 in there, has an old school air cleaner
...so he drives away and the serp belt shreds, was fine when I test drove it. Check the pulleys, good. Put a new belt on and it jumps half off. Whole alternator and power steering pump bracket is wobbling around can see it's broke off at the bolt ears... finally get the new one from ebay (no one makes that **** anymore) and tear it down.
