Does anyone happen to have measurements for a Chas Parker 436 swivel bolt? It's the bolt that holds the swivel base to the static jaw base.
I bought this vise, and it had been spot welded to a little metal cart, and the swivel mech was seized, so I had no idea that it was missing. Turns out to be a difficult part to come across.
My wife's dad runs a machine shop back home, so I just need the bolt measurements to get another made.
Any help would be greatly appreciated!
Sent from my SM-G960U using Tapatalk
Can you take the main nut/ spindle nut to HD or even better your local faster supply store and get something that fits? If it is too long you can cut the bolt to size with a grinder or hacksaw and chamfer the end.
I was missing the same bolt on a craftsman 51871- mine went thru the swivel base and then engaged with the triangular shaped main nut) and Home Depot had a bolt that worked fine.
As long as it isn’t a crazy acme thread you should be able to find it easy at the store. It just won’t be ‘OEM’
Hello gents, this may be my first post.
I purchased this American Scale Co Red Seal no. 66 vise. A lady was liquidating her deceased husband's tools and this was listed for $75.
I posted the pics to coax a little help from the gurus (with many vises).
This vice is missing the 5/8" swivel cleats and handles. What is the best way to fabricate or source this hardware? I bought some 5/8 carriage bolts but the flats don't quite fill the swivel slot. My next thought is to use T-nuts in the slots and grind them to fit the curved slot.
Thus far I have wire wheeled and greased all the machined surfaces. There was a lot of paint where it didn't belong. BTW what was the original color? I'm inclined to leave the paint as-is to show the age and history, but I will oil it liberally. I removed the jaws, clean and greased under them. The darn thing is so big, 24" long and 156lbs, that I may build an outdoor workbench for it. I already have a decent HF 5" vise/anvil that I like in my garage. I don't really have room for big bertha in there.
Enjoy the pics gents!
Hey 8T6ElCamino, I have a video on the restoration of one of those Reeds. I also have restored many others. Here's a link to the Reed......maybe it will help you. They are amazing vises!
Don't sandblast machined surfaces. Period.
Hello all. I have a Reed 105 swivel vise that I cleaned up a few years ago, but never fully re-assembled. Getting this sorted is one of my Pandemic projects, but I have an issue.
I would remove the slide from the housing then install the collar on the screw and make sure it is not binding. Put grease on the washer, collar, and on the shaft going through the dynamic jaw. Sometimes turning the collar around will make a difference in snug and jamming up. The next thing is the nut has to have a little movement in the mounting slot or could be in backwards ? and also check to make sure the screw is not bent.
Good Luck on getting it fixed.
In the photo below you can see the collar that pushes on the movable jaw, and the hole in the screw that it attaches to. Using a small machine screw.
What is the correct method or sequence for connecting the collar to the screw? When the vise is fully closed, The opening on the bottom of the slide has moved under the fixed jaw such that I no longer have access. If I open it enough to have access, the jaws won’t close fully after I attach the collar.
Thanks in advance for any help.
Kit
San Diego, Ca
you can now reinstall the complete assembly into the vise. ....
pro tip* when trying to insert the jaw assembly into the main body of the vise, you will have to push in on the center of the lead screw to get the threads to engage on the nut.
Gents is there any danger to sandblasting the acme thread and on a main handle?
I have a vise that had been outside for 50 or so years and part of the spindle handle is just pitted and nasty as ****. It won’t engage will with the main nut once the vise is within four or so inches of being closed. I don’t have access or the space to rig up an electrolysis tank so I believe sandblasting May be my only option- if it won’t wear down the threads too much.
Let me know talla thoughts.
TX, you should be fine punching the pins though. IIR they are not tapered.
You have plenty left in the nut to just go again with pins, but unless you want it 100% factory I'd tap the housing and put in set screws with pin tips. Then you can get them out at a later date..
Roger that.
I didn't know there were set screws with pin tips. However, a quick search shows only set screw with very short tips. Are you suggesting to also thread the holes of the end piece and then the pin tips would hold the vise nut in place?
Shift, the last 2 I bought off eBay were flat nosed.
