Some pictures from tonight’s quality shop time.
If you look at the driver’s rear quarter you can see where the plastic factory license plate holder had rubbed through the clear and base into the primer. This has bugged me ever since I relocated my license plate to the spare tire carrier a few months back.
On a side note, bonus points to anyone who happens to notice anything different. [emoji848]
I don’t use this particular CB antenna mount any longer so I thought I’d remove it and fill in the holes while I’m at it.
No turning back now.
To plug the holes which were 3/8” and 3/16” I used my 9/16” Hougen RotoKut cutter to cut a slug out of some 18-gauge P&O sheet metal. The ID of the cutter is 3/8” and the plug fit perfectly. For the smaller hole I used my Roper Whitney hand punch with the 3/16” anvil and die.
Test fitting.
Small hole welded and I used a die grinder with 1/8” grinding disc to knock the top of the weld down to nearly flush with the parent material, followed by a Rolex disk to bring everything flush.
Both blended and ready to hit with some 80-grit.
You can’t feel any deviation across the repair so all that should be needed is some epoxy primer followed by some primer surfacer then it should be ready to block, wet sand and go right into paint.
I should receive my order from SPI tomorrow with my epoxy primer, 2k primer surfacer and universal clear. I stopped by my local paint & body supply today and picked up a pint of PPG DBC 9700 black and I about had a heart attack when I saw a pint of standard base color was $106 bucks. I know it’s been a few years since I bought paint but daaayuuum.
