Coating Suggestions
krueges3
Minnesota
I plan to coat my garage floor in the next month or two and am currently thinking of going with Nohr-S for the floor or something similar. My question is what to do with the brick?
The garage is just shy of 1k SQ ft and it will be completely finished, I am just trying to plan this portion out.
Brick on the other side is waterproofed.
Sent from my Pixel 3 XL using The Garage Journal mobile app
SolarColumbia
Wisconsin
You can coat the brick as well, either with the polyurea or a less expensive acrylic, but you might just want to paint it.
Shea
California
Keep a paint stick with the cured coating on it and take it to your local home improvement center to color match for a concrete paint. You're not walking or driving on it (hopefully :)) so it will last years.
It can get expensive when you apply a coating to a lot of brick like that. It takes more than you think because it's much more porous than concrete.
K
krueges3
Minnesota
Good suggestion, I think I might go this route. Thanks!
usa#1
If your looking for a high end look, synthetic stucco works well on unpainted block.
