MJK
Hi All,
I have a 10 year old Ridgid RD80704 Pressure Washer. 6.0HP Subaru Engine and a Cat Pump. I love this thing, and try to maintain it properly. So, it is current on oil changes, air filters, plugs, etc.
Today, while using it, it started running poorly and then died. After some fiddling around, I found that it would run fine if I disabled the idle down feature. So, I finished the job and then proceeded to poke around a little.
I don't know much about carburated small engines, but from what I can tell the throttle works fine when the idle down butterfly is open (disabled). When the idle down is engaged, the engine slows but sputters and dies.
I'm guessing it is running too rich due to a faulty idle down assembly? Before I drop $60 on a new one, can someone sanity check me here?
