nathanras
I Have been wanting to start this thread for a while now and finely decided to do it. I am new at this so bear with me as i am learning the little tricks of this forum.
This thread is about all the cool tools and fun projects that I get to do at my job.
I work at a metal fabrication shop in Alaska. We do general fabrication but we specialize in tank fabrication. We are also a steel supplier so we have a large stock of steel and aluminum with some stainless. here is a list of the major machines that we have here.
400 ton press brake 16ft long
1/2" x 12ft sheet shear
18" x 22" vertical band saw with 60 degrees of tilt in both directions
1/4" x 6' plate rolls
1" x 10' plate rolls
3/8" circle shear capable of doing a 14' circle
3/8" circle flanger
2 iron workers
Tank weld-off machine
to many welders to count mostly millers but some Lincolns
5 plasma cutters
4 oxy/propane torches
1 10 ton bridge crane (2-5 ton hoists on one bridge)
2 5 ton bridge cranes
1 3 ton bridge crane
30' x 60' Blast booth/Paint tent
3 forklifts largest capable of lifting 36,000 lbs
and a lot more but those are the big ones
But my favorite and my main job is a Flow waterjet with a 6' x 12' table capable of cutting 10" of pretty much anything. It uses 60,000 psi water and a fine garnet sand to cut with erosion thru most all materials. it is an amazing machine.
A little about me. I have been working here for about 13-1/2 years now and running the waterjet for about 13 years. My main job is to run the waterjet and do the drawing/programming for it. But my job title doesn't end there, I am also the shops lead electrician, maintenance, mechanic, IT, the guy every one comes to when something isn't working. I service, fix and maintain almost every piece of equipment in the shop. I average 8-10 hour days but when there is a big projects I work long hours. My record was about 55 hours over 3 days. I knew how to operate almost every machine in the shop. The cool thing about my job is after hours I have full access to the shop and all of the machines I just have to pay for materials (which I get a employee discount on).
Any questions feel free to ask.
Nathan
3/8" circle flanger
2 iron workers
5 plasma cutters
Nathan
