My infloor heat
Right here
Just wanted to share some pics of my progress. Still trying to figure out what to do as far as separating my 2 zones. 52x64
yeldogt
what are the uses of the two?
You don't have to make general spaces -- you can heat them differently. Also -- within a given space. I always increase the tubing in the area where I'm working
U
Right here
The beam i have under my door I had made. Its 1/4 steel square tube with fingers welded on each side for the concrete to bond to. I did it for 2 main reasons. 1 ill never have issues with the concrete heaving and door not sealing. And 2 I filled it with insulation and I went 2 ft down. I just didn't want heat loss at the door. I know guys say its minimal heat loss .... but why have any? Why heat the outside?
78SC4X4
Port Orchard Wa
Pretty cool idea. Looking forward to seeing it with concrete in place.
Mancino
Upstate NY
I used the crete heat panels as well. I got them at a steep discount from the manufacturer because of defects...in the end, it was well worth the purchase. I did the tubing install in a few evenings after work.
