Stuff I do
sberry
Brethren, Michigan
I wanted to temper some water in 5 gallon buckets, add a little fertalizer and then dump them in pots. So,, it was causing root wash, was kind of difficult not to make a mess, some was probaby not even so I found this pump, wanted to drop it in a bucket, was in a hurry, cut a hose from stock, hose barb to shower head in which I had to drill out the restriction, an easiest thing I came up with at the min was to lasso it to a couple anti freeze jugs with some cheap electric tape. It's a top heavy little ****** and I dropped it 2x already.
sberry
Brethren, Michigan
Just a bit, having picture problems.
sberry
Brethren, Michigan
I should have got some smaller hose. I knocked the boxes to 3x4 which was kinda dumb,,,, but I love that hose, very stiff and pull it thru holes on the frame.
sberry
Brethren, Michigan
Needed to water some stuff and wanted a shower vs the fire hose it was. Small engine muffler screwed right on the end of the hose.
sberry
Brethren, Michigan
My dad put 12 sheet etalscrews in the muffler to reduce the flow of water. It had about 75 holes in it before.
sberry
Brethren, Michigan
I was headed for the trash can with this cat food dish that found its way in ending up laying by the hoist a week. I had a **** version of this but a couple holes and a tie wrap later have a "new and improved" lug nut holder on the hoist arm.
glen66
Oh I like that idea, gonna have to head to the dollar store and pick some up.
RivennHewn
PNW
Make do, or do without.
Don’t spend money if you’re smart enough to make it work!
