Conduit drain?
mcbane
California
My main panel is approximately 10 ft higher than a secondary structure. I plan to run PVC conduit underground from the main panel to a panel at the secondary structure.
In theory, properly assembled PVC conduit never leaks so I dont need to worry about ground water entering the conduit and then pouring into the panel at the secondary structure. But I have seen that problem occur before, likely due to a damaged conduit - water was pouring out of a junction box 2 ft above the floor.
Should I be installing a conduit drainage detail just below the secondary structure's panel? If so, what is the best practice approach?
nadogail
Coronado, CA
Could there be water form rain or another source getting into your system and running through the conduits until it escapes from the lower box?
mcbane
California
New install so that wont happen by design. The question is whether a drain is prudent just in case the conduit at some point develops a leak. I'm pretty sure the only time I saw this happen involved a backhoe that hat hit the conduit many years before, and probably cracked it.
wyliesdiesels
Modesto, CA
You will almost always have some amount of water in an underground pipe no matter how well its glued together. This is why its a wet location.
mcbane
California
I have seen the drain fittings but what is the correct installation? If I put one in a knockout at the bottom of the downhill panel I potentially have water flowing inside that panel. Is it ok to install one in a condulet tee below the panel, using a pipe bushing?
nadogail
Coronado, CA
I like those drain fittings. This is the first time I have seen one.
I am still learning about the limits of my knowledge.
rollinon2
Montrose, Pa
You can use electrical putty to plug the conduit where it enters the box so if there is any moisture it won't enter the box. We do this on conduit that transitions between hot areas to a refrigerated area. Condensation literally fills anything the conduit ends into. A large exit sign will fill to the top like a fishbowl in a few months.
alfredeneuman
Fullerton, CA
10 feet of head pressure, 4.3-4.4 psi, will leak right past the electrical putty. I've tried it in a similar case and finally had to drain drill a hole in a conduit body to stop it.
