Hey, new here.
I'm just got done digging the footings (by hand) one my to be 26x44 garage.
I dug them 12in wide and 32in deep. I'm going to put 2in foam board on the inside wall and pour this trench full up to ground level. I will add rebar of course.
Then I plan to ether forum up and pour or lay concrete block up to floor level. That will get me 6in above the road.
My question is, have any of you poured the garage floor inside the frost walls and not over the wall where the garage door openings are? My thinking on this is that way the whole floor could move if needed. Typically I see on jobsite that everybody leaves the wall cut out for the man doors and overhead doors. Then when pouring the floor it goes out even with the outside of the concrete wall. Seems to me that would street the floor in those areas.
Also, if you poured the whole floor inside the walls then the whole slab would be insulated by the perimeter 2in foam board that would be cut at a 45 on top.
Thanks
Thanks
