overkill19
The Milwaukee addiction thread! [emoji4]
Just bought this on Kijiji, brand new in box, I haven’t even seen it yet as my niece is picking it up for me.
I watched lots of reviews on you tube.
If it’s half as good as my little 1/4” impact it should be good. I mainly bought it to have in my toyhauler on long trips.
What do you guys think? Seemed like a good deal, $475CAD vs. Over $620CAD plus tax
Worst case I buy a tool only mid torq and sell the high torq!
DerekV
Central TX
Got sick of Milwaukee dragging their feet, and sick at the thought of spending MX Fuel money for the likely upcoming MX Fuel variety, so here we go. M18x2 and/or M18x4 brushless lawnmower. Just a few 10AWG M18 pack adapters, genuine Wago Levernuts, and extra wire/spade connectors/electrical tape/etc. and you’re good to go.
The 6Ah Ryobi pack takes 3 hours to charge and just barely finishes my ~1/4 acre yard. All things considered though, it works surprisingly well. Four M18 5.0s makes a 10Ah “pack”, and all can charge simultaneously in ~1 hour with my bank of standard chargers. I also have the option to run just 2 M18 packs, i.e. a pair of 12.0s or 9.0s. My goal is not only to have more battery options, but also to decrease wear and tear on whatever batteries the mower is using. Fully charging + fully discharging a pack (my only 40v Ryobi pack I might add) is a good way to guarantee a limited life. The 5.0s should allow a full mow without a full discharge.
I think it’ll be wise to keep the packs the same models and to make sure they’re all at the ~same resting voltage level for safety and pack longevity reasons. Actually excited to mow the lawn now :D We’ll see how it goes tomorrow morning.
48548
Phoenix
I think that is a great idea.... i am still waiting on a leaf vac.
Sent from my SM-N975U using Tapatalk
DerekV
Central TX
Post-mow follow up: excellent results. Some before/after observations:
BEFORE
Ryobi 40v 6Ah pack (10S-2P)
Ambient temp (last mow) = 91*F
Pack temp after mow = never measured, but definitely very warm, probably ~115+*F
Start voltage = 40.9v
End voltage = 33.9v (“one bar” on fuel gauge)
Grass = dry and light, but dense Bermuda. Fertilized 10 weeks and cut 8 days prior.
AFTER
Milwaukee “40v 10Ah pack” (10S-4P via four M18 XC 5.0 packs)
Ambient temp (this morning) = 91*F
Mower “battery bay” peak temp = 104*F
Start voltage = 41.5v
End voltage = 36.6v (“two bars” on fuel gauge)
Grass = same Bermuda but tall, wet, and heavy. Fertilized and cut 7 days prior.
Notes = no pack movement or loose connections (bumpy back yard, too). Wiring/junctions did not heat up, actually cooler than packs (ambient). Mower seemed to wind up with slightly more authority and fought off bogging down noticeably better on near stall conditions. All packs charged up to and discharged down to within a 0.04v window (charged high = 20.78v, charged low = 20.74v // discharged high = 18.30v, discharged low = 18.26v).
Verdict = success, very worthy modification if both caution and common sense are exercised.
[emoji106]
Black300zx
Elkton, Md
Re: The Milwaukee addiction thread! [emoji4]
[emoji106]
Very neat project! I guess I never realized that "40V" was a bit of a roundup and was really just a pair of 18V packs in parallel. I have nothing in the M18 or Ryobi 40V platform, but I do have a small investment in Ryobi 18V tools (backup drill/impact driver, radio, lantern, OMT, leaf blower). I have ~1/8th acre of my yard that I push mow (takes ~10 minutes). I wonder if it might be worth doing your mod, but with my Ryobi 18V batteries, if my gas powered push mower ever dies.
DerekV
Central TX
Thanks! I’d definitely do it, although the included 40v pack will probably do you just fine. It is nice to have other battery options though. This mower with a revised 6.0 pack (10S-3P w/2Ah cells vs. 10S-2P w/3Ah cells which is what I have) and charger is only $259 at HD right now. I don’t even know if you can get this mower as a bare tool.
I also modified the handle brackets a bit to fix a design flaw, I’d definitely recommend doing that. If you are thinking of getting one, PM me for details. I wanna keep the “M18x4 Ryobi mower” topic as Milwaukee as possible in this thread [emoji23]
RKA
Isaias dropped my neighbors tree on top of my shed and the corner of my house. I would estimate it’s a 50-60ft maple. I used the M18 hackzall to get this far, climbing up onto the tree or a ladder to get the taller stuff. If I’m up for it, I’ll take out the chainsaw tomorrow and start chopping the bigger pieces. Town will only pick up 6ft and 60lbs pieces until next Friday.
Black300zx
Elkton, Md
Good point, I had assumed that it was available as a bare tool.
Bighead38
Rockland County NY
How far down in Jersey are you? I’ll drive down with my friend and we’ll cut and stack it for you. For a small fee.
chappys4life
Is the 1/4 ratchet worth it? Found a 3/8 & 1/4 ratchet set non-fuel for 120 locally. Wondering if it’s worth it to have the 1/4 ratchet or just buy the bare 3/8 off amazon.
Odd-job
I think so. Am currently looking for 1/4 myself since I am sick of sticking an adapter on my 3/8. This is also a result of GJ convincing me to up my 1/4 socket selection.
That’s a decent deal if the ratchets aren’t beat to ****. PM me if you go for the deal but decide not to keep the 1/4 :)
RKA
Too late unfortunately, but thanks for the offer. I got out the chainsaw and got it down to this today. Rest will wait for a tree crew. Why? I don’t have any use for firewood, town won’t pick up anything heavier than 60 lbs and that remaining trunk (20-25ft) is perched flat against my shed and on that smaller branch. I decided it would be wise to stop at this point.
Hammer1963
Kentucky
I have a mower like that and have thought about adapting the M18 batteries as well. Now that you have made it look easy, I believe I will have to copy your idea!
Ign
Butte Peak ND
Yes.
But seriously, Milwaukee could have moved that content from the end of the instructions to either the "Setting the clock" section OR "Setting the radio preset" section, because neither will stick without those batteries.
:dunno:
IME Milwaukee's printed instructions are always poor. The things you REALLY want to know are buried in crammed paragraphs, if they're mentioned at all. You can almost always learn more from reviews, YT vids or product announcements than you can their instructions.
In unrelated news, I'm beginning to wonder how I ever got by without the little M12 3" cutoff tool. It's great for cutting apart tack welds, and is probably the best thing I've ever found for ripping 1/2-13 expanded (unless I want to take the time to painstakingly set up a fence for the plasma). It's also very useful for complete weld beads, but in smaller stuff like 1.5" x 14ga square tube.
Ultimately it's less drama than a grinder 'cause you can hold it with one hand and help stabilize the work with your other. Plus, unlike a grinder it can't really get away from you and fawk something up.
dacan23
RI
Great example is the drywall gun nor the collator instructions tell you that you have to remove a piece off the chuck to get the bit to fit with them together.
Wanna Ride
How is the antenna and the FM reception? The specs and reviews also say the battery lasts about ten hours, would you say that’s accurate and which battery are you using? Found several reviews online, but haven’t spoke with someone who actually owns one. And we all know online reviews can often be superficial.
I’m planning on buying one of these in the next few days. Not for the shop or jobsite, but just to have in the house in the event of a power outage. We don’t get many of those, but want to access local stations when we do. Cell service and internet access also turns to **** if the storm is bad enough to knock out the power. And... it’ll be perfect for the occasional need for a bluetooth speaker in the house too. This one seems to check all the boxes for me.
New Bluetooth radio/charger arrived today. So far I really like it.
javyLSU
New Haven, CT
The Milwaukee addiction thread! 😊
So far the FM reception has been great, and that’s with the LED lights on in my garage, which can interfere with reception. I’m using a 2.0 battery on it, and I would estimate it lasted between 8-10 hours, mostly streaming from my iPhone. I really like it so far - it’s way more than I need for my garage, I have to keep the volume turned down to about 1/3 of the max, which I can conveniently do right from my iPhone. It’s also nice to be able to charge batteries (both M12 and batteries chargeable through USB), I’ve used that feature several times already. [emoji106][emoji106] from me.
Pitalplace
North Platte, NE
I have the 2890 and the reception is horrible. I wish I could find a better antenna or get rid of this. If you live in the city it may work better
alex50
NYC
Recently changed sliding closet doors to mirrored sliding doors for a couple of bedrooms in the house. I needed to trim the top and bottom metal rails of doors slightly to make it fit. It was the perfect job for the M12 FUEL™ 3" Compact Cut Off Tool. Made quick work of it and am happy to have the tool in my collection.
1320
Arizona
I'm late to the party on the M12 right angle die grinder, but I just picked one up and I like it so far. I also like the sponge looking stripper discs, which I had never used before - now I feel like I have been missing out all this time.
I got one of the 6" braking grinders and I REALLY like it. I don't think the regular Fuel 4-1/2" is any slouch and this one is even more powerful. I do feel like having the right batteries has to go a long way. I can see disliking all of the grinders if you don't have any of the modern batteries. The brake is nice, but not that big a deal to me.
pwschuh
Mid-Atlantic
Went one step deeper into the abyss yesterday by picking up a 2522-20 bare tool M12 FUEL 3" compact cut-off tool at HD.
It works great but man does this thing chew through my tiny 1.5 batteries. Time to step up to something larger.
1320
Arizona
I like the 3" cutoff tool. I love the shoe/guard and the fact that you can change the wheel direction. It does eat batteries, though. I use mine with the XC6.0 with good results.
dacan23
RI
Sophisticated security measure for open house as we are moving
Wanna Ride
Bought one of the new M12 radios (2951-20) yesterday. FM reception is great out here in our rural area, and all “local” channels come in fine. This is going to be perfect for all my needs. I was very happy to hear the sound quality and volume level, plus I discovered it has adjustable bass and treble levels. I put a partially charged standard M12 battery in it, and used it at varying volume levels on radio and Bluetooth source for a total of six hours and thirty four minutes before it died. I also charged my iphone for just over thirty minutes to get it to 100% (started charging it at about 45%). After the M12 battery died, it took one hour and twenty-four minutes to charge the battery back up to 100%.
Phoenix
Works the packout be better than the old boom box? I like it takes m12 and m28.... but i have close to 20 m18 and 10 m12 batteries now doesn't matter. Does it pick up am? Why no one does an hd radio is beyond me... not for quality for the sub channels I can't get any other way or they are stronger....
Wanna Ride
Yes, it’s an AM/FM receiver. But I don’t listen to AM, so I’m not concerned with any AM reception. I have some specific needs for this particular radio, and it checks all those boxes for me.
spyerx
SoCal
I want to thank this tread for funneling money from my bank account. I replaced some larger RIGID which worked fine but the sizes annoyed me for my type of use.
I love the M12 size for the automotive and around house work I do. Picked up
M12 Fuel hammer drill (which i use mostly as a die grinder LOL, works fine for minor Roloc cleanup on brake hubs)
M12 Fuel impact driver (I use this mostly as a screw gun the low speed is fantastic for that and stops right when torque is reached)
M12 Fuel 1/2 stubby impact (this thing is GREAT!)
M12 inflator
M12 LED task/stick light thing
M12 rotary tool
Batteries: 2x 1.5, 2x 2.0, 1x 3, 1x xl4, 1x xl6
The inflator will do a whole car from low pressures with the 4. The 6 stays on the impact. The 1.5 will run the light for hours. I use the smaller batteries on the others.
I think I need that little sawzall for tree cleanup... the die grinder would be nice to have... the little saw...
Farmer888
Ontario canada
You did good! its the 2767? I bought that new and paid the full price and really happy with it. Bought a grinder off kijiji brand new as well, I just wonder how many of these unused tools are stolen? I didn't ask lol
dacan23
RI
Wish I didn't miss this deal, did get the backpack vac with 5.0 $249 deal and the 3/8 extended ratchet kit with metric ratcheting wrenches $329, paid 15% less after using my rare coupon
Black300zx
Elkton, Md
So....I've had my first M12 purchase that I'm luke-warm about - the M12 jigsaw.
Good power, good battery life, but the sawdust just kept piling up in front of the base, covering up the line I was trying to follow. The blade also deflected a lot during turns.
Perhaps it was the material I was cutting (3/4" MDF)? Perhaps the deflection was the junky kit blade? Perhaps I just got spoiled using my dad's corded Bosch which has the air puffer to keep the cutting path clear and a little pair of clamps that laterally support the blade?
My main use right now is rough-cutting material before routing it to match a template, so it's more than adequate. Just a bit concerned that it won't cut it (pun intended) if I have a project that requires more accuracy.
techieman33
Kansas
I haven't had blade deflection problems, but yeah the dust really does pile up in front of the blade.
dacan23
RI
Cant remember if my buddy has discussed his experience with run time. Thanks for the tip, I have plenty of 8s and 12s, the 8 is my fav battery now a days.
That vac needs an 8, 9 or 12 ah battery
