atourgates
- Joined
- Dec 15, 2010
- Messages
- 24
Just like the title says, those of you who have glass garage or shop doors (either aluminum full-view, or insulated steel with glass panels), what's your experience been like? Long term, how have they held up? Would you do it again? What would you do differently?
We're nearing the completion of our 44 x 60 pole barn in North-Central Idaho. It has 3 overhead doors at one end, two that are 9' wide by 11' tall, and one that's 12'-wide by 14' tall. Our dream, for the aesthetics and light, has always been to have glass overhead doors, and we've been budgeting for those since the beginning of the project.
Now that it's time to finalize the doors and put down our deposit, I'm looking for any real-world feedback on various options.
Broadly those are:
In every case, we're planning to leave the bottom panel aluminum or steel, just since that's the most likely to get hit by a ball, or other stray object.
Currently, we're leaning towards Aluminum full-view with 1/2" double-pane insulated glass for aesthetics and some insulation. The shop will be heated with radiant heat (powered by an electric boiler, with a roof-mounted solar system that should offset most of our electric bill). We're planning to keep it ~50F in the winter, warm enough to melt the ice off our vehicles and for kids to play. I'm having it wired so that I can add a supplemental mini-split if we want to warm it up for a few hours, but that probably won't get done before this winter.
My biggest concern about the double-pane insulated glass is condensation between the panes, since that's an issue we have with the windows on our house.
The rest of the shop will be insulated with R-21 fiberglass, behind 1/2 ply sheeting.
Pricing from our 3 local dealers seems to be about the same (Cloplay, Wayne Dalton and Amarr) and - the Amarr dealer has been the most helpful and well regarded by other tradesman and homeowners I've talked with so far, so I'd prefer to go with them unless there's a significant difference in their product.
Obviously the big advantage of the insulated-steel is an actual R-value, and doors that come with a lifetime (instead of 3-5 year) warranty, at the sacrifice of some aesthetics.
Broadly those are:
- Aluminum full-view with a single-pane, uninsulated glass.
- Aluminum full-view with 1/2" double-pane insulated glass.
- Insulated steel, with insulated glass panels throughout.
