The short answer on the forklifts is, I don’t know exactly. I wanted to have two electric units, one for the Hill and one for the SG, when I bought the orange one last year, it was supposed to be for the battery, but it worked very well so I kept it. It leaks really bad and the fix is not cheap, this latest one does not leak by needs a battery, so my thought was to just swap batteries and then I would have a decent non leaky forklift for the Hill. As for selling the leaky one, I would most likely keep it for parts since I have the other two that are pretty much the same units. The battery is worth something in scrap too, probably close to $300, depends on the weight of it. This particular brand has shown to be very dependable, so I probably won’t need much for spare parts, but you never know, once the forks are off, it doesn’t have a very large footprint, but I would probably just pull off certain parts, then take it to the scrap yard and be done with it.
If I end up staying at the hill, I will need another rough terrain lift like Clark, the one I call Smokey (formerly known as Guido) will work fairly well for right now, but I need something that can actually go up and down the hills since everything is terraced. I actually have a line in another Clark, but it needs some work, probably be worth the effort in the end, but I may be better off spending more money and buying a heavier duty unit.
