Automatic Wire Stipper
mobiledynamics
Gotham City
Working on some large SO cord/plugs/etc..
Used my older -preferred- paladin wire stripper.
Have a stripmaster - don't prefer to use it that much. The auto stripper work and works well...
Have taken a brief eyeball at other auto ones on the market. Nothing said I must try ....to compare to the Paladin auto. So I come her to the GH brehtern to ask if there is anything to look at .
ez-duzit
Marina del Rey
I prefer this style.
nadogail
Coronado, CA
For SO Cord, I have only used a good utility knife And great caution.
SO and SJO Cords are not easy to work with but they are good for what they are intended for.
ez-duzit
Marina del Rey
Try carrying it in a pouch my statement stands, fine for bench work.
Don't care to argue against misinformation but, if your pouch is too small, figure out an alternative.
Virtually all my work is done in situ, on yachts, frequently in rather confined spaces, sometimes from a bosun's chair hanging off a mast. None is bench work. This tool has proven itself over decades of professional use and is highly recommended for producing impeccable work, particularly when "on the clock" with no time to waste. And particularly where only the highest quality work is acceptable.
Typical compact combination stripper/crimpers are often a struggle when stripping, especially with heavier gauge wire, and are known to do inferior crimps. The automatic strippers greatly improve the speed and quality of one's work and go hand-in-hand with better-performing ratcheting crimpers.
Norcal
It's stupid to have a huge pouch, carrying a large pouch leads to back problems, to waste precious space to carry a bulky toy, BTW 40 years ago though those strippers were the cats meow,now a basic Ideal stripper, serves me well, light weight & very effective.
HenryAZ
MEMBER EMERITUS
South Congress AZ
If you have a lot of stripping to do, all the same wire gauge, I prefer to use the Wiha industrial stripping tool. The jaws form a diamond shape that can be adjusted for 8awg to 24awg. Once set, it make a clean, perfect strip job. For me, it's not worth setting up for doing multiple gauges on a job, because it takes some trial and error settings to get it just right for a certain gauge.
mobiledynamics
Gotham City
Henry. Got that in Knipex I think. Will need to rumble around the tool drawer. I recall hating it on initial impressions. Enough that I don't even know what drawer it owuld be
Bretny
Dutchess county NY
I use the ones pictured above. They work very well and are quick. Other types require two hands or you to really yank on the wireing. They also strip in corners really well. I have had these for over 10yrs.
CJ7VFR
Central New Jersey
I have a very similar set of wire strippers that I bought from Harbor Freight 30 years ago. The difference in mine (besides being from HF) is that the handles on mine are red. They can strip wire from sizes 18 thru 10 gauge, which is great for everything I have from lamp cord to running wire for my generators power inlet box. They have lasted 30 years and still work great.
Besides being fast, and idiot proof (which is why I bought them) I like that they can easily strip short wires that always seem to be inside electrical boxes in walls, where the original person installing the wires always seems to cut the wires too short.
I have tried to use manual wire strippers/crimpers in those instances, but the short wires and lack of room inside a crowed electrical box prevents being able to get a good grip on the wire with one hand while using the manual strippers in the other, and then pulling on the stripper to get the sheathing off the wires.
These only require one hand to operate, and the head of the strippers only need about an inch of space to move in order to strip a wire.
Jim
alfredeneuman
Fullerton, CA
I've owned a couple of these for bench jobs, but never seen one on any construction jobs.
To do so you would be taunted and laughed at (with good reason)
HenryAZ
MEMBER EMERITUS
South Congress AZ
It is a bit of a pain to set up, unless you hit it right the first time. Several trial and error adjustments, which is why it is only good for doing a whole bunch of the same size wires. Normally, I grab my Ideal T-Strippers, I have both sizes, which give me a range of 8awg to 26awg.
CJ7VFR
Central New Jersey
True.
Maybe by the old timers, but there are a lot of new guys coming into the trades that don't even know how to remove the outer sheathing from cable to expose the wiring, or which direction the wire loop should go around switch and receptacle screws. Now that is something that would get taunted and laughed at with good reason on a job site.
However, we are not talking about construction jobs, or what a real pro electrician would use. We are talking about what DIY guys, and garage journal guys use on their home projects. And for those projects, or bench jobs as you put it, the one handed strippers work great, are fast, give uniform and repeated results, and don't nick or damage the copper wire if you use the correct size spot on the stripper.
Jim
ez-duzit
Marina del Rey
For the jacket on multi-conductor cable I just slit it between the conductors, then bend back and trim the two halves using my zero-offset cutting pliers, which everyone should have for trimming TyWraps.
