2020 - What are the Masses Using as a Beer Fridge?
Maddog1337
Plainfield, IL
Hi GJ,
Planning out my garage, I'm curious what people are using as beer fridges. Yes, I've used the search function, and while refrigerator technology has not necessarily changed, there are definitely a couple new models out there.
I was reading a thread on here about someone looking at USA made commercial lines True and Beverage Air, but those are probably out of my price range, as much as I want one.
I could consider a larger overflow type fridge, or one meant for a small apartment enclosure, but half the battle for me is the aesthetics, not that 60 Miller Lites jammed in a fridge is that ****.
Myself I'm particular to something with tempered glass - I've been looking at some of the Danby beverage centers with a glass door, however I definitely question the longevity of a cheaper mini-fridge. I guess you get what you pay for.
What are people using? Pictures are encouraged!
Thanks in advance
sreeb
SoCal
I have had two Danby small refrigerators (no freezer) in my outdoor kitchen. Neither really cooled a beer or Coke to my satisfaction. It helps to take one from the bottom.
AldeanFan
Niagara on the Lake
When my garage fridge quits I’ll buy whatever they have in stock at the scratch and dent store.
I bump the fridge with the car at least once a year so it’s going to get some dents anyway. Rockauto magnets and racing parts stickers cover the dents up.
My garage fridge used go be our kitchen fridge. It’s a full-size GE bottom drawer freezer stainless unit.
When it was our kitchen fridge It stopped working and the repair guy wanted $900 for a new circuit board and 48 hours to get it. The milk had already gone bad so I drove to the appliance store and brought home a new kitchen fridge that day and put the old kitchen fridge in the garage until trash day.
Then I found a replacement board online for $150 and fixed the fridge. It’s been running happily in the garage for 8 years now.
Doozer75
Buffalo NY
I have a small apartment fridge in my machine shop.
It is made in china and it was a garage sale buy, think I paid $30.
Magic Chef is the brand, but they are all made in china with a different
name slapped on them. It is 33" tall, I think they call it 4.4 cu ft size.
It will hold 24 beers/sodas, whatever. Serves my needs super well.
The other week I had a problem with it. So far it had been running
perfectly for 3 or 4 years. It was making a loud click and the compressor
was not coming on. The click was the thermal overload cutting out.
I went behind and felt the compressor, and it was super hot to the touch.
I figured the compressor was toast. So I remembered Lowes and HD sold
these small fridges, so I went online and looked at prices. HD had the regular
fair, and Lowes happened to be having a back to school or back to college sale.
They had my exact fridge, normal price $200 on sale for $120. Great I thought.
I was going to go out and buy it, but then I thought... Maybe I should check
the compressor one more time. I remembered that aside from the obvious
thermostat inside the fridge, they sometimes had a starting relay, as most
single phase motors need some way to activate the Start winding.
So on the back of the fridge is a wiring schematic, and there it was. Some
some component called a PTC Relay. I found it under a plastic cover, where
the wires plug on to the compressor. It was a plastic box, the size of an ice
cube. Kind of like an electrical plug that connects to the input pins of the
compressor, with something inside. It had a thin cover with a stainless steel
clip. I removed the cover and inside was some thin steel bent to form a
spring terminal affair. 2 of them actually, and in between the spring terminals
was a disc the size of a nickle. I wondered what it was. I grabbed my needle
nose pliers and pulled it out. It looked like sintered metal, and was silver or
some kind of solder coated on both sides. It was actually broken, with 1/3
or 1/4 of the edge broken off. I did not have high hopes of fixing it, but I
thought maybe polish it up and put it back together and see.....
The side where it looked like melted solder or silver plating, I took a file and
made it smooth again. I bent the spring terminals in the housing so they had
good tension on the disc, and I re-inserted the strange disc into the plastic
housing. I plugged it back on to the compressor. Then I tried the fridge.
I plugged it into the wall outlet, and it started up ! ! ! Great I thought.
I un-plugged it and waited a few seconds, and plugged it back in again,
and no luck, it just hummed like before. So I took the relay thingy apart
again, and the disc was super burning hot! Nothing I could do, so I put it
back together again and tried it. Well the fridge started up running again !
I left it to run, and just to see, I left it overnight.
The next day, the beer was cold and the compressor was fine. I felt it
with my hand, and it was only slightly warm. Great, I fixed it, but I was
leary about that disc with the broken off edge. I guess filing off the solder
and re-bending the spring terminal was the fix, but there was a part number
on the relay cover. It was P6R8MC. I looked it up on Google and they were
selling them on Amazon and Ebay. HuuH! I found a new one, same part
number, on Ebay for $5 and free shipping, from a USA seller. Great.
So I find out PTC relay means Positive Temperature Coefficient relay.
The disc is some mix of semiconducting elements, that pass current
when it is cold, and itself is resistive, so it heats up from the current, and
then as it gets hot, it conducts less, and severely limits and all but cuts off
the current flow. I am used to mechanical start relays, with a real coil
of magnet wire and contacts and such, that sense current magnetically.
I never seen a PTC device before.
But anyhow, my beer fridge works, and I have a new spare PTC start relay.
I will probably put the new one in, but so far it works. I am glad I diagnosed
the problem, instead of buying a new fridge and sending my old one to the
landfill. I hate this throw away consume consume consume society.
So happy I was not drawn in for the on-sale fridge at Lowes. For a little
thinking and diligence, my fridge is fixed. And a $5 part assures a permanent fix.
I hope my story helps some people here, should they ever experience a problem
with their fridge. If you called a repair man, it would likely cost $300 for them to
come out. And for a $200 fridge, no one would really do that.
-Doozer
welder4956
Birmingham, AL USA
I have the $200 Lowes version. My wife bought me one of these last week for the garage:
Edit: Added a pic of the fridge.
DeeDubz
Socal
I have a cheap fridge we bought at Bestbuy. Its about 4 yrs old. Nothing fancy but it keeps the beer frosty. I used to have my kegerator in my garage but it was kinda hard to keep the beer cold. The micro fridge that I have is sorta cheap. Once it gets really hot the beer gets warm. So i moved it inside for now. Im in the process of covering my fridge in stickers.
TriumphFan
North Georgia
I have a Hisense SS in the mud room just off the garage. Nice looking fridge, LEDs and all that but... what is odd is the only place I can put tall glass bottles is in the doors where they rattle around. Also, the freezer portion does not have shelves but bins so storing glasses is more of a pain than it should be. It's more than just a beer fridge so whatever. Before you buy be aware that there are new refrigerators out that that are less than optimum for garage/beer fridges.
rsparks64
Hill Country Texas
We have a smaller size fridge like you might find in a small apartment. It was scratch and dent from Best Buy with a small dent below the handle. It makes nice overflow for the kitchen fridge freezer and fridge compartments. We keep extra frozen food, all of our Blue cooler/freezer blocks that you put into ice chests and that saves a lot of room in the house refrigerator. We also keep at least a case of water, a case of soft drinks and gatorade, and beer in that refrigerator at all times.
ER70S-2
My keezer
larry_g
oregon
We have a local independent appliance sales and repair shop in Salem. He will custom build a freezer into a refrigerator. I have one of those. A 20 cuft box that has no freezer compartment in it. All new compressor. controls and coils. All steel shelves and linings.
lg
no neat sig line
nadogail
Coronado, CA
Whenever a tenant leaves something behind after giving me their keys, that becomes my new whatever.
I have received sanders, refrigerators, furniture...
Lots of cool stuff and some trash.
LX-Markham
Markham, Ont.
Another vote for the small Danby fridges. We put a fridge and freezer in our basement reno. Great to have the extra room. Plus wife like that it keeps all my beer out of the fridge in the kitchen.
MotorCityBear
Blairsville, GA
I bought an LG stainless 20 cubic foot stainless steel frig/top freezer from Home Depot for $599 a few months ago. It works great and looks good in my new garage
2Busy
Williamson Cty. Tennessee
I have an old Whirlpool kitchen fridge bought for our first house in 1988. It’s moved cities 3 times with us and is still going strong. It’s been in garages with no climate control for the last 20 years. Definitely don’t make ‘em like that anymore.
Bigbandguy
North Carolina
Here are a couple of pics of my garage beer fridge. We rescued it from our boathouse. The future will probably have a hammered green paint. At least I know now where the ski rope had been hiding.:lol_hittI
View media item 106041View media item 106042
I have one very much like that that I know for a fact was bought in 1938 by my grandparents. That fridge is very likely around 80 years old.
LS6 Tommy
Northern NJ
I can vouch for danby. I have a dishwasher from them and it has not given me any problems in the 3-4 years Ive had it.
X2 on Danby. My original bar fridge is a Danby my parents gave me 27 years ago when we bought our house. It has never skipped a beat and is still in service in my boiler room as my beverage cooler overflow storage unit.
Tommy
NUTTSGT
Northern Central Ohio
I have a small dorm sized unit. Generally not but a few beers init but it does a nice job.
I wish now I had a one slightly bigger with a freezer for a bag of ice or box of ice cream treats, popsicles or ice cream sandwiches.
PhantomEB
Medicine Hat, AB, Canuckistan
I got a refurbished Danby 20 years ago for my dad’s garage.....5 years ago when I brought my house, mom got me a new Danby....needless to say two weeks later I swapped the new one for my old one. It keeps the beer way colder!
BaMaDuDe87
AL
Good thread.
I need to start looking for one to pick up in a few months. Was thinking about just picking up a new fridge for the kitchen and moving the current one out to the garage.
Gerald O
NC
This is what I use for a beer fridge. Holds up to 72 long neck bottles.
engineer2
Chicago burbs
You might look for a TRUE GDM 12 or similar. Popular glass door commercial fridge. You can often find used ones for under $1000. Check Milwaukee CL.
Bretny
Dutchess county NY
danfromsyr
Cicero, NY
garage ready means it's designed to work in greater environmental temperature variances
a regular home fridge is generally expecting to be in 'conditioned' space and won't be efficient or may likely run too much and overheat in garage in summer
but I think what 'garage ready' really means is it's set to 1970's fridge specs.. (compressor size, condensor size, freon qty, and insulation amounts)
Lassen Forge
I figured it was being marketed to people like us with shops, looking for a beer cooler for our "garages", so it's a cheap and easy marketing ploy... Otherwise it's a realtively small, relatively ugly conventional freezer-top fridge like the ones in apartments for decades...
I'm split between the soda machine and the beehive, tho the Westinghouse would also have a place of honor... ANY of those would be welcome.
I have my old dorm fridge (from, egads, decades ago) that still works (and works well), and a small (pony) Kegerator. They usually migrate to the porch for barbecues, as they're small enough to move around, then back out to act as sentinals for the shop.
Ilikeike
Northern Ca.
I have my grandmas 1947 sears fridge in the shop at work, but it's a little small and needs defrosting often, it looks cool though.
At home I bought a 1 year old used side by side about 15 years ago,I think I paid $300. large Ice storage, great for filling up a medium beer filled ice chest, and cold water in the door.
And since I'm 6'4", I don't need to bend over to get to the beer. I do not like bottom fridge top freezer style for that reason.
Glemon
NE
Maybe I am old (yes) or run with the wrong crowd (probably) but the best beer is free beer. The best way to store beer is a free fridge. Most all the garage and shop fridges I am aware of are hand me downs from a remodel, upgrade or move, if it keeps things cold it fits the bill.
When we got a new refrigerator for the kitchen the old one went out to the garage/shop which was across a walkway five feet from the kitchen, so not only great for the shop, but great for having people over and keeping the extra food and beverage cold and handy.
Copymutt
Colorado
Bought this 15 cu ft used in the mid 80’s. Gutted the shelves and rack. Replaced the inner door w/ 24 ga. steel. Holds 3 cornies ( 5 gal. soft drink kegs). Runs nice & cold.
