TT_Vert
I've got exposed rafters in my basement and despite rewiring the lighting in the board for 3 1W LEDS they just don't cut the mustard. I'm going to run a box (either round or 4", not sure yet) to the area and want to conceal the fixture as much as I can. The pics I attache will make what I'm about to type make sense. First my goal is to use a fixture can can rotate and pivot as well as one that will accept a smart spotlight/bulb. This will be an always hot circuit which will be controlled by google home. I had originally considering running the box out past the duct shown and use a track light just in front of the duct and using smart GU5.3 but that may be bulkier than I want. This wouldn't look horrible and I could use 3 lights and center them perfectly. I then though perhaps if I were to mount the box above the duct on the joist i could have one spotlight up there which is atop the duct and all you would see is a bit of the lens of the light. This would be a very clean install and I do plan to paint it all the same color as I painted the entire ceiling. I always love your creative opinions and any fixtures you may know if that may fit the bill. I guess the biggest thing is it needs to rotate and pivot as It's going to have to turn 90 deg. plus if I mount the box flat on the joist. I could go w/ something as simple as this outdoor type of spotlight if it rotates as well as pivots. Hard to tell from the images on HDs site. I could also go w/ a smart PAR 30 as I have a bunch of them but I feel that may be too big/bulky. It seems the PAR/BR 20s are mostly for track lighting but those would probably be a size I'd be more happy with if anyone knows of any of those.
