One thing I considered for my shop was "tiered" lighting. I have different levels of light available to me depending on the tasks at hand. My workbenches all have overhead directed track lighting (all now have led reflector bulbs), in addition to general lighting from hanging T8 fluorescent fixtures. The most used lighting, however, are white ceramic fixtures that hold reflectors and accept a standard base bulb (E26, I believe). They are also outfitted with a cage to protect the bulbs from breakage since I started out with CFL 23W bulbs (mercury?). I have since switched to LED bulbs (A19 shape) in the ceramic fixtures. My shop is not only a woodworking shop, but, like many DIY folks living rurally, it houses "everything in the world" to keep up a house, travel trailer, and fix lawn and garden equipment for a large homeplace. I have two fixtures near each entrance and two in each of the other building corners. Each fixture holds an LED bulb that provides enough light to go find, fetch, etc. It's a little more to wire in initially, but when you are in and out working on things you may consider that burning 50 Watts total and leaving the lights on when your hands are already full a great convenience. My T8 fluorescent fixtures (30 bulbs X 32 Watts per) are on four different switches and provide great light when woodworking; they're just not always needed. All the fluorescent fixtures plug in to four-square boxes so they can easily be replaced if /when necessary. I had only one corner of the shop where the switch turned on power to both ceramic fixtures and two four-bulb troffers. I recently separated the two lighting systems with a remote controller (think Christmas lights) and that worked fine. I always buy the 13A or 15A rated remotes and have had my small dust collector on one for five years with no issues.
