99graveyard
- Joined
- Apr 5, 2016
- Messages
- 14
Hi All,
I have a Quincy 216 that I would like to find a motor for. As I understand it this pump is rated at 500-900rpm with a 2-3hp motor. I would like to be in the upper range of that for the cfm increase. I could buy a newer 2 pole 3hp motor (3,450rpm) that would put the pump in that rpm range. I’ve also read that newer motors are more efficient. However I’ve read a lot of post where folks prefer 4 pole (1,750ish rpm) motors. If I go that router than I would have to change pulleys to get around 800 pump rpm, the pulley reduction would be close to 2:1 then. Wouldn’t it be harder on the electric motor with less pulley reduction? Thank you all in advance!
