old 3/4" ratchet disassembly
kaliona
Found this 3/4" ratchet in a freebie box at a garage sale. Looks to me like it should ratchet in either direction depending on which side of the handle you push drive head. I can feel it ratchet once or twice, then it gets stuck. I'd like to get this to work because its made in good ol' USA, feels beefy (weighs 5.5 lbs), not some crappy Chinesium metal. It's about 18" long, 1" diameter handle. Can anyone tell me from the pics how to open the head to get to the ratcheting mechanism?
DadsTools
Those indentations may be for a special tool to unscrew the cover.
You might also try posting this in the Vintage Tool section, where some members are more focused on these old tools and may have additional insights.
plinker
Northern Wi
You flip the square drive around to use reverse, common on some older stuff. Non reversible ratcheting wrenches are the same principle. It looks to me like the four marks may be staking marks, hard to say 100%. Soaking in ATF or similar would likely be the most help.
lardy1
My guess is that it's threaded into the main body of the ratchet. I have an old Williams that is threaded.
The guys over in the vintage tool forums can probably walk you right through it. Some very informative folks over there.
K
kaliona
This is the other side of the head. I soaked it for a while in Kano Aeorkroil and it now moves, but in both directions, one way a little easier than the other. Feels like the pawl is not completely engaging the internal gear.
How do I move this this to the vintage forum?
K
kaliona
Thanks guys. I'm not a collector and if I can get this thing working I will definitely use it. I am going to post in the vintage tool discussion.
davethorik
Norka, Ohio
The indentations are where it was pressed/peened together at the factory. You could open it up but you will have a hard time not destroying anything. I would leave it in a bucket of ATF for a while. Truth ratchets are unusual vintage tools, I would definitely avoid damaging it.
Where are you located?
Shiftless
East Bay SFO
I second the suggestion to soak some more in ATF or Marvel Mystery Oil. Both of those fluids have worked for me to free up stuck mechanisms. Fully immerse the head in an old jar or whatever you have handy.
Soak, take out and exercise back and forth, soak again, repeat as necessary. So what if it takes a week?
K
kaliona
I'm in the beautifully burnt state of California. I'm letting it soak in ATF for a few days. I'll let you know how it turns out.
