Jswain
For $200 I would think you could make some pretty good $ flipping that if everything works.
For the lights I bought a strip of 3m clear bra off amazon for $10 and cut strips to fit, enough to cover them 20x each
https://photos.app.goo.gl/d2zTrexCR2VQAi4w6
https://www.amazon.com/3m-clear-bra/s?k=3m+clear+bra&ref=d6k_applink_bb_marketplace
3m paint protection film like they put on bumpers and hoods etc
No problem. Haven't had it in long enough to see how well it lasts but ill be using the cabinet tomorrow for 4-5 hours straight so it will be a good trial for the window screen/led lights/3m film
Clear bra?? Can you explain and provide a link
I bought this compressor, now deciding if I should flip it?
If I were closer you could use my big cabinet, I think it needs 70 CFM
Let us know how things go
to:930dreamer
thank you so much for posting the cartridge filter conversion on your reply (post #660)
cesarbee440
Curious why the one square piece has fabric sandwiched in between. It mounts below the channel that's tack welded about 6 inches from the bottom. Dust collector will end up with the cartridge filter conversion sometime.
930dreamerThe ones in my large cabinet have a metal frame at the open end that the bags are glued to, and have steel wool type material inside.
930dreamer
are you doing the cartridge filter change?
Petersen dust collector I'm rebuilding but not sure if these are even the right filters. I bought 10 and with shipping, handling and tax cost me $400.
On the Goyen brand pulse valve both 3/4" from Baghouse.. One is listed for $28.97(RCA 20T000) but another (RCA 20T001) is $68.87 and they look the same. I wonder what gives?Hey 930....
Those Pulse Valves listed as McMaster Carr 5496T11@ $57 can be had a lot cheaper from Bag House......
http://sales.baghouseamerica.com/pentair-goyen-valve-replacements/
Was able to compare descriptions side by side on the similar looking Goyen brand 3/4" pulse valves and the more expensive one has a diaphragm for a more extreme heat operation. So compared to McMaster Carr at $57, this brand is only $28. Two for one!
I would think you'd just set the pressure switch on one about 5 lbs lower than the other? Then when the pressure drops, one kicks on, then the other kicks on. Maybe set them both to about the same turn off pressure? No money to spend with that setup. Not sure why or how a timer would be useful?? Your 'guy' might just want some of your money
