jonness
I'm getting ready to run power from my house to my detached garage. I'm using 2 AWG copper underground 130' using 2" conduit.
I'm not sure what the best way to get the wire into the house load center is?
I plan on drilling a hole in the siding and fitting a 2" PVC LB conduit body from the outside. But I'm not sure what to do on the inside of the wall. Should I come in from below the panel and use another 2" LB body on the inside of the wall and then a short piece of conduit into the knockout on the bottom of the panel. Or should I go directly into one of the 2" knockouts in the back of the panel?
Note, the space on the wall on the outside of the house limits exactly where I can place the LB body. (please see attached images)
Thanks!
Thanks!
, or #1 AL to go easy on the wallet
