KMScott
ChefRex:
That split nut looks damaged to me. The red arrow points to the area I’d be concerned about. It’s risky to take that out.
The black arrow points to what I’d expect to see on a split nut.
Maybe you don’t REALLY need to disassemble it to clean it up. If that split nut falls apart, I don’t know where you’d get a replacement.
I had a Reed once with that split nut arrangement. The previous owner evidently had trouble so he just welded it up tight. Not cool!
A while back, IIRC Joe Striper had a split nut made by Kevin Scott. Kevin may be able to give you some advice as to what to do for a replacement. (Kevin is "Out of the Business, but maybe his successors can help.)
PghJKB
The Collar is a two piece design and machined from cast material. After it is machined then it is broken most likely with a chisel. There is plenty of threads so cleaning up the chewed area will not effect the collar to much. I added a couple pictures showing what the spindle and collar looks like, Reed also added a hardened washer so be sure to not loose that. Clean everything as good as you can and maybe use a STP slippery type of oil to help you un screw the collar. I used a punch and the spindle handle to un screw the collar instead of beating on it with the punch.
---Nice find.
, I guess I had to prove how easy a repair it would be...
