Anyone buy a used 15 ton crane
930dreamer
Amarillo,TX and Stinnett,TX
I know I have at least two buried fuel tanks on my shop property. Looking at a Batnam crane 12 miles from my shop.
930dreamer
I concur but there buried in a direct path from my power pole to the North wall of the shop where i need to trench. The shop is near a small town that I doubt would see or say anything.
driftpin
Have you scoped-inside? How-empty are they? Are they still intact? Pretty-sure there would need to be the EPA involved for a removal, and your local /state Dept. of Environmental Resource Management, or whatever they're called. Mitigation of the site could be a really-expensive headache, if they've leaked.
https://www.tceq.texas.gov/assets/public/comm_exec/pubs/rg/rg-475m.pdf
https://www.epa.gov/ust
Where are the outriggers for that crane? I don't see any. That could be a real-problem.
loganb
Omaha, NE
Unless you already have th equipment to excavate the tanks, a track hoe seems to be a better buy than a crane as with the hoe you should be able to both dig them out lift the tanks up once unearthed.
If the tanks were properly closed up I'm also in the leave them be and trench around them camp.
Sent from The Garage Journal mobile app
sberry
Brethren, Michigan
Properly closed up,,,, this I doubt. Put a stick in and see if anything is in them first. Get rid of them if they are manageable,,, depends on the size? Like a lot of threads this is incomplete and all simply speculation.
Nothing is as good as gone. We had some kind of audit for insurance and they asked about buried tanks,,, I said,,, none for decades, any were torn out and gone. They didnt ask for any more details.
txvwnut
Bedford, Texas
Instead of buying something that may be a money pit just rent an excavator and do it like the companies that remove tanks do. Dig around them smash a hole in the top away from the access hole run a chain through and lift with the bucket.
AA/FC
I'd rent a fairly large excavator and have it delivered to my site. Use the excavator to dig around the tanks AND use it to lift the tanks out of the ground. I wouldn't tell anyone what I'm doing.
jonesg
northern Maine/
Its illegal in some (liberal) states to DIY,
typical EPA approved contractor cost is $10K and up.
it might be a good time whilst the EPA is currently defanged. Depends where you are.
2oolhound
BC Canada
They are the rusty squares you see at each end. I think they telescope straight out and then tilt down slightly as they are already quite low. Rusty pads pivot down as soon as they extend past the cam built on the cylinder, or something like that ;).
driftpin
Yeah, I am not familiar w/that crane, I'm not an operating engineer either. They looked like some-sort of counterweights to-me, I didn't think they were the outriggers.
sberry
Brethren, Michigan
What that crane is nice for is a small steel director to leave right on jobs, pre engineered building type stuff. Lots of stuff to go wrong with something like that, none of it cheap and lots of it complicated.
I do wonder what that crane 12 miles away has to do with digging up a tank.
930dreamer
I guess for now I'll rent another excavator to remove the last few tree stumps and dig around the perimeter of the tanks to get an idea of what size tanks are.
sberry
Brethren, Michigan
Depending on the soil,, not sure about Texas but can even hand dig small ones out. Throne the dirt far enough back starting the sides, follow curve half way down and dig a ditch along one end. Can hook in a bung and rig a pry up, even pull with a pickup. Can cave in drag out, any number of things.
A couple strong guys can roll 500 gallon, even tip one in a pickup easy enough.
sberry
Brethren, Michigan
You can pound a rod, can even simple drill to find size. I did a big one for a church way back in the day, we cut a hole in it with a sawzall, dumped 5 gallons of soap, stuck an extension on the hot pressure washer washed it all around and sucked it right out dry with a vac truck. Then filled it up with sand, buried it up.
That must have been 30 years ago. I don't even remember why I was there,, I remember, was to rig the steamer, went down to the hwd to get extensions.
OHMS LAW
Houston TX
Something that old I’d double and triple check that winch cable. Also you’d have to check the hydraulics. Theres a a lot that could be wrong with it. No telling how it’s been used. Shock loads are hell on a boom.
sberry
Brethren, Michigan
I agree, old crane, I have seen it work but usually highly experienced men with a purpose that makes sense. There is a right kind of owner for something like that.
crane operator
sw missouri
Not much for parts available for the bantam. They are old and obsolete and have no value except as scrap.
Looks like the hyd reel for the boom laying by the engine compartment. Looks like they've managed to two block it also.
You could spend $5,000 easily getting it operable. Three times that if you want it to pass a inspection, and that might not be enough $$.
