The issue I have with the cheap calipers, is that the batteries die if you leave them installed. They also turn themselves on with the slightest movement most times.
I have one on the lathe and one on the mill for rough use. The accuracy is not bad.
I have none of these issues with any of my Mitutoyo or Starter calipers. Those are just too nice to keep out on the machines.
Sent from my SM-G975U using Tapatalk
Here's some AWD Mits (the prices don't appear to be astonishingly cheaper than retail):
https://smile.amazon.com/gp/offer-l...p_twister_redir?ie=UTF8&qid=1600717842&sr=8-1
Also knock-offs are a very real thing here, so on places like eBay (and I found some on wish.com for $29 via Google), if the price seems too good to be true, walk away. The fakes also pull the battery down even when not in use per studies done by people who have researched this in the past.
iGaging are really good budget calipers.
These are the two different models I would suggest
https://www.amazon.com/dp/B001AQEZ2W/?tag=atomicindus08-20
https://www.amazon.com/dp/B00INL0BTS/?tag=atomicindus08-20
Fowler has some good ones for not terribly expensive, along with they're moderately expensive ones.
I wouldn't buy anything subject to counterfeiting from amazon. Amazon comingles stock from multiple vendors, so anything they ship, no matter who the seller is alleged to be, can be fake. Buy them from directly from an industrial or tooling supplier.
Dial calipers are great if you work in a clean environment. Dirt and metal chips will destroy the rack gears and cause them to skip/jump numbers.Why do you need a digital one? My Fowler dial caliper is good to .001 of an inch. It will never need a battery nor die because a battery decided to self destroy on it.
I have Mitutoyo calipers both at the shop and at home. They are the industry standard for a reason. They're just really nice calipers for a very fair price.
Why would I want cheap **** at home? Its not like good calipers are expensive. We're talking $100 or less.
Threads like these bring out a strange part of this board.
I don't understand why if someone says "hobbyist" or "DIY" folks automatically assume they mean "cheap or inexpensive".
Somehow, we've intermingled DIY with "low budget". When I DIY something, I want the best I can get my hands on. I HATE using cheap tools. Just because I'm not making my living with something I can't use the good one? When did this become the norm in thinking?
If we look at tools as a hobby, which some here do, it doesn't seem to line up with typical hobby spending. Guys will spend THOUSANDS and THOUSANDS on electronics, guns, tractors, classic cars, collectibles, golf, bicycles, and who knows what else for their hobbies, but we somehow assume they're unwilling to spend more than a harbor freight budget on their tools?
When I shop for my hobbies, I get the nicest things I can afford in that area. If it is something I enjoy that much, then I want the good stuff.
If you truly can't afford something, then that's one thing. I don't think anyone is saying you should choose between tools and your light bill. But if you're just being cheap for no reason, well I have no comprehension of that.
It just seems weird on a board of tool collectors and enthusiasts we have such a large amount of people who constantly recommend getting the cheapest thing you can get away with.
If you use your tools even more than just occasionally, I would want at least average to "good" stuff for the vast majority of your collection and really spend the money on stuff you'll use more often. You don't need to buy the best of the best for everything, but if the good stuff isn't a hard get, why not get that?
The price difference between some very mediocre calipers and some very nice calipers is only like, $50. That seems like a very easy sell to me.
The only thing I might be inclined to recommend on a quality scale between HF and Mitutoyo, would be SPI.
I've held everything from no-name dial calipers to Starretts to beautiful swiss-made Brown & Sharpes. If you get sand or dirt in the rack, the pinion will skip and your measurement will be off. There is no away around it.I take it you have never held a Fowler or similar caliper? the solid stainless steel construction could probably eat sand for breakfast while maintaining the .001 accuracy.
Not to mention that mishandling of a tool is not the tool's fault. If you are using a high precision instrument while metal chips are flying you are doing it wrong; wait for the dust to settleI'm pretty harsh with my tools and yet if I'm in need of that level of precision I can slow down enough to pull the caliper out of its pouch, use it, and put it back.
They're great tools in the right setting, but there are much better options for a set of general shop calipers. Digital ones are far superior in that regard. Shoot, I'd probably rather have a vernier than a dial caliper for general shop use. If I'm under the back of a dirty rusty Jeep, measuring shims to set-up a rear axle - I'm not going to be using dial calipers, that's for sure.
Exactly. I really enjoy using dial calipers. As 908jim mentioned, they have a really nice action/feel to them and are satisfying to use.Dial calipers can and will get debris in the rack no matter how careful you are. You clearly haven’t used yours in a machine shop.
Eventually it WILL happen if you use it outside of a clean inspection room.
The one and the only Mitutoyo. Buy once cry once. For about $100 they will last forever.
