bulletpruf
I use a come along fairly often -- usually pulling non-running cars into the garage or on a car trailer (I have a winch but haven't always had one). I also use around the yard periodically.
My latest one was the HF 2 ton unit. https://www.harborfreight.com/2-ton-cable-winch-puller-61964.html It wasn't bad, especially for $22, but the cable has a habit of binding up and I've jammed it up a few times and tweaked it to where it's out of whack and time to toss it. I had to pull a car into the garage this past weekend using ratchet straps.
Whatever I get, I'd prefer to stay under $100 if possible. It also has to be manual so I can use it anywhere. It helps if it's fairly compact, too. Certainly nothing larger than the 2 ton HF come along.
Figure I could always step up to a better quality come along like this one, made in the U.S. for $50. https://www.amazon.com/dp/B00004Y68X/?tag=atomicindus08-20
I'm also curious to hear what y'all think about a chain hoist - HF makes one for $100 that would work, but it only has 5' of chain. Guess I could get one with longer chain. https://www.harborfreight.com/1-1-2-half-ton-lever-chain-hoist-66106.html?_br_psugg_q=chain+hoist
Forgot to mention - here's a decent thread on the subject, but not directly on point - https://www.garagejournal.com/forum/showthread.php?t=289848
Thanks in advance for any input.
Scott
Scott
