39CAMC
For some reason, I just can't think through this....
At work, we have the compressor towards the front of the building. We have a long skinny space, 40' w x 150' long.
The compressor is plumbed with (new 4 y.o.) 3/4 iron pipe for the first 25', then I did the back part of the shop with a 3/4 Rapid Air Kit.
My alignment rack and tire machine are down at the far end of the shop/line.
Our compressor turns on at 90 psi and off at 135. It is a 10hp compressor with 120gal tank
The issue is that by the time the compressor kicks on, the pressure loss at the far end of the line has it down to 60-65psi and the tire machine air functions are basically useless at that pressure. The alignment rack jacks are also slow at the low pressure, but they at least work. When this equipment was up front, closer to the compressor, it worked fine as pressure never dropped below 85-90.
We have a second 10hp compressor with an 80 gallon tank and I am trying to decide how to use it to help the problem.
1) Will using the second compressor as a storage tank only, either in the middle of the line or at the back help the pressure drop?
2) Will hooking the 2nd compressor up, either in the middle of the line (preferred) or at the end, help? I don't have 3phase/220 electric down at the end of the line, plus I am trying to stay away from the noise, hence my reluctance to put the 2nd running compressor down there.
2a) What other issues do I create with 2 compressors on the same line?
If both of these ideas ****, I could split the line in the middle, use the existing compressor to feed the front of the shop and then hook up the 2nd one to the back part of the shop, but this is least preferred as we wouldn't mind having two compressors available to work everything in an emergency.
Thoughts?
DaveW
Thoughts?
DaveW
Plus it saves your motor from cycling.
based on his air demands.
