The Best/Most Durable Garden Hose
Yost
Bit of a long one here, sorry. TLDR: Continental Frontier is the best garden hose in my opinion.
The Problem:
My 8 month old Neverkink hose just busted a big hole in it. Grant it I left it pressurized and in the sun, but still, not even one season? So this made me quite upset, and started me on the road to try and find the absolute best quality, most durable hose currently made. You know, the type of hose you would bring to Mars to water your biodome garden. And since I found the best advice/reviews on old Garage Journal threads, (indicating that crappy hoses are in fact a problem for others, not just me) I thought I would post what I learned here.
Summary of Past Advise/Research:
I combed through past GJ threads and counted the number of explicit recommendations (not including things like “I bought X 2 weeks ago and it seems ok so far”) for each hose. I counted whatever I saw, so I probably double counted within or across threads, and I may have missed some too, so I don't claim this to be 100% accurate. I looked at a couple of tractor/farm forums, but they weren’t good enough (# of posts, and personal experience in each post) to include in this analysis. The Craftsman black hose was far and away the winner according to GJ (see attached table). However my main criterion, longevity, is a lagging indicator, by maybe 10 years, and we all know craftsman is not what it used to be. There are some recent reports that the new craftsman hoses are not as good and are marked made in china. Also I don't like that I cant find out who makes Craftsman hoses, which makes it impossible to tell what is really going on.
https://www.garagejournal.com/forum/showthread.php?t=173672&page
https://www.garagejournal.com/forum/showthread.php?t=323599&page
https://www.garagejournal.com/forum/showthread.php?t=450725&page
https://www.garagejournal.com/forum/showthread.php?t=202575&page
Based originally on GJ recommendation, and now some of my own experience, I can tell you that rubber hoses are the best. Sure they are heavier and might kink more than the vinyl hoses, but they recover immediately, lay flat, remain flexible in cold weather, and are much easier to wrangle into a coil or figure 8, and are reported to last way longer.
My Opinion on What Makes a Good Hose:
So if not the craftsman, what’s the best rubber hose? Here’s my opinion: you want something industrial, rated for high temperatures (>180F or preferably 212F), and high working pressures (>150 PSI), and preferably rated for air and water. These specs are overkill, and as max WP goes up, so does the weight, so that’s something to keep in mind; but things tend to last longer when operated well below their max. High temperature ratings are necessary if you want to leave your hose in the sun like me, or drain a hot water heater, and generally indicate a higher quality, longer lasting rubber. Black asphalt can get up to 160F, in Phoenix AZ summer for example, so a black hose in the sun would probably be similar, making a 212F rating look less absurd.
Now here is why I advocate for an industrial hose. If a garden hose fails, a homeowner gets wet. If a 3/4” 200 PSI air line fails, it can whip around and cause serious injury, which is unacceptable for the commercial hose purchaser, who will make it unacceptable for the hose seller/manufacturer. Unlike individual consumers, industrial purchasers can actually enforce consequences for poor quality. These industrial hoses are also essentially a commodity, they have guaranteed specifications, and identification markings printed along their length detailing manufacturer, product name, part no, max WP, and made in USA. Rubber hoses are marked with a manufacture date as well. This is how you know it is a serious hose, and also makes it easier to buy with confidence.
I’m sure there are a number of hoses that fit this description, but I only seriously looked into a few: Parker series 7092 gst II, and Continental Frontier. Both are rated for -40 to 212F, air, water and limited oil, and come in 200, 250 and 300 Max WP options. (Note that WP is not the same as burst pressure, which is typically listed on consumer garden hoses because its ~4 times higher than WP.) For reference the black Craftsman hose is rated for 160F and 500 PSI burst pressure, likely 125 PSI Max WP. Goodyear/Continental garden hoses are well regarded here, so they are an obvious place to look.
https://ph.parker.com/us/en/gst-ii-general-purpose-air-water-hose
https://www.continental-industry.co...tipurpose-hoses/productsna/_base/frontier-200
Fittings should be brass, crimped ferrules. Aluminum leads to corrosion and galling problems. Since these are industrial hoses, you can’t by them straight from Continental or Parker with fittings pre-assembled. There are some people selling these hoses with steel bands holding on the fittings, ( https://adamspolishes.com/products/...rFGGMkXX4LiyUQspocWlusO4Jm_i8ZcBoCAZoQAvD_BwE ) because this is a lot cheaper than buying a hydraulic crimping machine but this is sub-optimal, essentially an upgraded hose clamp.
See here for hose clamping:
https://www.crossco.com/resources/technical/industrial-hose-secure-clamp-styles/
https://www.mbaa.com/brewresources/...Box Talk -Hose Fitting Attachment Methods.pdf
The Hose I Bought:
This may seem overkill and unnecessarily difficult, but these type of hoses can be had for a decent price (~$100 for 100ft of 5/8” or 75ft of 3/4”), though I will say it took me a while to find my 3/4"x75ft with crimped brass garden hose fittings. This is more than cheap vinyl hoses obviously, but on par with some of the higher quality consumer garden hoses.
https://shop.amazonhose.com/product...ier-water-hose-coupled?variant=35439121334435
JGB hose quoted me a bit higher, but it was a custom hose.
http://www.jgbhose.com/Data_Returns/detail_market.asp?marketID=1&id=3&prod_id=301199
I ended up getting a 3/4"x75ft Continental Frontier 200 hose from Amazon Hose; cost me $107 shipped, which is not bad. So far it seems great, but I can’t tell you yet if it will last me 20 years as I hope. The machined/cut brass threads are thick and way better than the formed/stamped fittings on the green (5/8 diam for reference) hose next to it (see attached image). The hose is a bit heavy, and does not twist, which can make coiling it harder, but also helps to keep it from kinking. A heavy hose that doesn't get tangled up in itself is actually a lot easier to drag than a light, tangled hose.
Anyway, this is just one man’s (long) opinion, thought I’d add it to the internet for others to take into consideration. I welcome comments, as would future readers I imagine.
Now to find the best nozzle... any suggestions?
Odd-job
Following. Sounds like a great hose you speced there. 3/4. Brass. Pure rubber sounds like the way to go.
I have been getting by with 5/8 continentals (former Goodyears) from Home Depot and also bought a few Flexon industrial hot and cold 3/4s with brass fittings which was about as good as I could get off the rack. $70 for 50 ft 10 year warranties. Definitely never going back to 5/8 as the increased flow is noticeable.
Am contemplating making my own gardening water wand. Melnor from Home Depot took a **** in less than a week and I can’t even blame it on the kids. Thinking about cobbling something together off of McMaster or Zoro.
JBH
For drinking water or home garden watering I think the current advice is polyurethane leeches fewer chemicals into the water than others. A company in Oregon called Water Right makes them. They sell online and also through a few home/design chains.
matt_i
SE Michigan
Goodyear UltraGrip makes a very good water hose although its an air hose. The AutoGrip line is an even better hose than that. Although these would be very heavy to handle as compared to traditional.
Seems to me like the hot ticket would be a push-on deep barbed fitting except with the GHT garden hose thread female swivel. Then a person wouldn't even need the exterior band nor the crimped ferrule.
Chucktin
Interesting discussion. One thing you all are ignoring tho (and I came a-cropper on) - wife. My DW absolutely, _absolutely_ refuses to use a heavy hose.
Sent from my Pixel 4a using Tapatalk
Quick240
Omaha, NE
The hexagonal craftsman rubber hoses are considered "the good ones". I have one that is over 10 yrs old and another 2 years old. Both still look new. You can still find them at Ace Hardware I think. Very durable but also very heavy and kind of a pain dragging around the yard.
CTyankee
CT
I've got one of those Craftsman hoses too and rarely use it. Weight is going to be the biggest factor tor me what I need a hose for.
Best is certainly going to be subjective from one person to another...and durability doesn't necessarily coincide with best. :wtf:
The most durable hose(which will likely be quite heavy) is never going to be the "best" one for me. I want a hose that I can pickup/move/store easily without needing to break out the hand truck. Those lighter ones tend to be cheaper and not very long lasting So I'm relegated to classify hoses as another throw away item.
FWIW, I also won't buy a hose longer than 50', and more often than not, 25'. If I need a longer length, I'll string them together. Same with extension cords. YMMV.
pepi
Woodstock, GA
Black rubber, like Sears once sold. Before the thieves bankrupt them
The ones that shop garage sales. Return the junk they never purchased, turn around a sell .
Ain't it great !
HenryAZ
MEMBER EMERITUS
South Congress AZ
Goodyear rubber (I believe this is what Craftsman sold). Goodyear is now Continental, but sells the same product. I have a couple of Goodyear black rubber hoses that have laid in the hot AZ sun, pressurized, for 10 or so years now. They are well worth the money, and it is all I will buy. The color fades a bit over time, but the hose remains intact, doesn't get stiff or anything, coils easily.
Y
Yost
Thanks for the comments, while I have obviously already bought this one, I will likely need another for the back, so I am glad to hear opinions, and am not blindly attached to the Continental.
Also yes I prioritized durability over all else, we'll see how that plays out with the weight issue as I use it.
JBH mentioned drinking water safety, which I think is an important point. My wife is hesitant to water the food garden with a non potable water hose, but these get expensive or lower quality. Thoughts?
Nick Danger
Albuquerque
The best sprayer is a T&S Brass MV-3516. I've put hundreds of hours on the brass and stainless model and it never even needed to be rebuilt.
Zmann
Arizona
wow those ELEY hoses look like a great product. not too off the wall price wise
I use the black rubber goodyear but they can start to make your hands black and they sure work well as solar water heaters lol
Never Kink mfg advertising is a joke ,, insta kink is more like it
I think MFG's that sell hoses with deceptive brass colored Aluminum fittings should have to pay for the damages to hose bibs and hose end sprayers
Wamsutta
Amarillo, Texas
The best garden hose is Thermoid and I say that with a high degree of certainty. I get mine at California Industrial Rubber. They have standard lengths and custom lengths. Diameters are 5/8 and 3/4.
TheoShooter
Southern Illinois
I own a large greenhouse operation and we literally have hundreds of hoses, could be over a thousand, the best hose you’re going to find is Dramm Colorstorm hoses.
cbracer
Costa Mesa, CA
I have one of those. My issue is the memory effect when rolling and unrolling it. I use a hose pot, so I have to twist the hose as it goes into the pot and out of the pot. Not really ideal unless you have lots of time on your hands. Very nice hose and great color, but rolling it up isn't fun.
Ralf11
Yup - so what's the best light wt. hose?
M635_Guy
NC
I use ELEY hoses. Hot Florida sun, easy to use, easy to carry, easy to roll up, safe for drinking water. Made in USA [emoji631]
www.Eleyhosereels.com
I also have an Eley hose and am very happy with it. I also have a real-rubber hose from Griot's Garage that I'm sure is a re-label from somebody, but it's been terribly treated for a number of years and is holding up fine.
