Can somebody recommend a half decent sand blasting gun?
Don1357
Palmer, AK
Nothing crazy, something with a good bang for the buck. Ideally something Amazon has.
My 60 gallon compressor is rated for 13.5CFM @ 90PSI
Thanks a bunch.
D
Don1357
Palmer, AK
Thanks, most appreciated. I should have been more specific. I'm building a sand blasting cabinet, I'm looking for something with a feed tube.
Jswain
Calgary, AB
If you're building a cabinet build it with a metering valve on the bottom and a triggerless gun with a foot pedal. Thank me later. Eastwood sells a kit to get you both gun & pedal for pretty cheap then build your own metering valve, but shipping to Canada led me to build my own & pick up the holdwin style gun on Amazon. For you it is likely a very good deal
I got the one with the pistol grip same style as Eastwood but if I were to purchase seperately again I would go with this for better clearance in the cabinet without kinking the suction hose:
https://www.amazon.com/dp/B07X4C9R1M/?tag=atomicindus08-20
Link to Eastwood gun & pedal
https://www.eastwood.com/eastwood-blast-cabinet-foot-pedal-and-gun.html
Jswain
Calgary, AB
Do not get the cheap pedals that are on Amazon with the small orifice holes. Spend the money on the Eastwood or similar pedal or buy the valve yourself (3/8 whistle valve) and build your own. I believe most come with a 1/4 whistle valve which I'm sure is fine as well but I used 3/8 when building mine, again because shipping to Canada would have been 2x the cost to build alone
This is the style you want:
https://www.amazon.com/dp/B006YWU6IO/?tag=atomicindus08-20
Do not even be tempted with this style :
https://www.amazon.com/dp/B00Z5AK7TY/?tag=atomicindus08-20
And then either buy or make one of these:
https://www.amazon.com/dp/B078L7GDYY/?tag=atomicindus08-20
Diy version:
https://images.app.goo.gl/RnU3V2zoj558aaPP6
Metering valve is the best upgrade so don't skip that. I build mine out of 1" black pipe tapered down to a 1/2 hose
