Smallish update. Between the weather last month and being busy at work. I was too tired and stressed to get much QST.
Sometime last month I did get the interior of the Mack truck finished.
20200904_190936 by
bjohnson388, on Flickr
20200906_161107 by
I put a coat of BLO on the pumpkins and then 2 coats of Spar Varnish.
20200912_182147 by
I love their color.
20200920_145525 by
I have had this rusty clamp for I dunno how long. Well I finally got it functional.
20200920_145154 by
20200927_084653 by
Just a quick cleanup so I could actually use it without getting rust on my hands.
20200927_084704 by
While I was sandblasting the clamp I decided to blast one of the old hand wheels.
20200920_153631 by
It was just for fun.
20200920_155141 by
Came out pretty good.
20200927_084737 by
During this whole time frame I was trying to diagnose something wrong with the 95'. Drove it home from work and it ran like piss and gave me a code 42. Which is a Lean O2 code. Which could be a lot of different things.
I kinda through some parts at not really being able to diagnose the exact problem. It had spark and the injectors were firing fuel during crank.
This model of truck does not have a fuel pressure port. There are a couple of work arounds but I didn't really want to spend $40 just to find out I needed a new fuel pump. So I just bought one because it has 173,000 miles on it.
Here are the parts all OEM. New coil, rotor, cap, fuel filter, O2 sensor and the big one which is what I suspected. A new sending unit and fuel pump. It's crazy it made enough fuel pressure to idle but would not start. On a TBI if you pump the gas pedal while starting it squirts fuel like a carb. So several pumps during cranking and it would start. But when you tried to drive it just wouldn't accelerate above 1500 rpm.
20200924_161244 by
And while I was trying to diagnose the coil, and Ignition control module my old Craftsman Multimeter finally kicked the bucket so I had to get a new one.
20200902_085521 by
Well fast forward to today I started a 10 day vacation. And the first thing I wanted to tackle was the 95' The pump has been sitting on the bench for 2 weeks.
It was a nice change to see both stepsides in the garage. They are 31 years apart.
20201002_075624 by
Grandpa's homemade trans jack to the rescue again.
20201002_081552 by
I took this picture for you guys up North. This is what a 25 year old Texas truck looks like. Damn near perfect.
20201002_081606 by
Wasn't too bad of a job. Would have been much easier on a lift.
20201002_085427 by
20201002_090426 by
Halfway there.
20201002_095524 by
Success it runs great now! The only downside is the fuel gauge is still not reading right. Either the ground wire is not making good contact or the gauge is bad. I am going to take the ground wire lose and sand down the are where it contacts. Cross my fingers and hope that's the problem.
The truck will actually pull past 3,000 rpm now. Which it would never do before. But I won't be doing that much on this tired old 305. Just glad it runs good again.
20201002_115510 by
And since I had this old girl out I gave her a bath.
20201002_121248 by
She is all clean now.
20201002_123940 by
I then washed the wife's car and was planning to wash the 95' but I just ran out of steam.
Last thing. I found this a couple of days ago. I struggle really bad with motivation last month. This pic definitely helped me get going again,
FB_IMG_1601233215509 by
Thanks for stopping in,
Bret
