ovilla
Code for my basement is that all outlets have to be GFCI protected. I have a wall where I want to place two outlets. One outlet will be a GFCI protected outlet and the second one will be a regular one, which I’d like to split into half hot - so one side is always hot and the other is switched. Hence half the regular outlet will be fed from the load side of the GFCI outlet and will always be hot. The other side of the regular outlet will also be fed from the GFCI outlet but it will go to a switch. So, in the end the regular outlet will always be protected since it’s connected to the GFCI outlet but half of the outlet will be powered by a switch. Basically I want both outlets to be GFCI protected, like the code states they should be, but one half of the regular outlet will also be switchable (while still always being GFCI protected). Note that I’m using a normal non-GFCI circuit breaker at the circuit panel. The only thing that is GFCI is the first outlet, which feeds the other outlet and the switch that gives GFCI power to the other half of the outlet. Anybody see any issue with this wiring plan?
Also, yes, I know that the switch will basically not work if/when the first GFCI protected outlet trips and that’s fine - and expected, as that would happen anyway if a switch was wired to a GFCI protected outlet anyways.
to this ^^^^^^^
