ajt976
Hello fellow garage junkies! Long time lurker/newbie here seeking advice for the initial planning of what will be my future 'basement shop' for our new construction home. We are currently finishing up the architecture phase so looking to get some input before we get the plans engineered. Please realize, my setup is far from ideal that presents some unique challenges and I understand that I will need to make compromises, just hoping you all who may have experience with this can help point out things for consideration before we begin building.
Essentially we are planning on utilizing a suspended slab (poured slab over steel decking) in our 850sqft garage that will provide around the same space underneath for a shop. We are doing 9' foundation walls so my guess is I will have somewhere around 8' ceiling height with the main support beam dropping down from there (height TBD). The current plan is to have that beam spec'd large enough to allow for a single post in hopes of keeping as much open floor space as possible. Our lot is a walkout, and while our final grade has yet to be determined the goal is to have access to the shop from the outside via overhead door as well as from inside the house with a 32" man door. Attached is a rough sketch of the space I'm working with and the adjacent basement areas, I've tried to add enough dimensions to give an idea without going overboard haha.
Overall this shop will need to be multi-use as well as some level of storage for outdoor equipment and a UTV (not sure if HOA will allow a shed). I like to dabble in a bit of everything so being able to keep the shop flexible to a degree is kind of what I'm after. Currently my interests are in woodworking and have started my collection of equipment (contractor table saw, router table, dust collector) with the hope of potentially getting into some automotive and welding projects if I have reasonable drive up exterior access to the rear of the shop.
My mind is all over the place trying to plan things out. I guess in general my question to you all would be what features would you recommend putting in this space this size and what all should I try to get added during construction? So far my thoughts are at minimum at least one floor drain, a utility sink, and a sub-panel. Anyone have thoughts on ventilation? Would you consider adding a second man door into the 'future bathroom' or opt instead for a dedicated urinal in the shop (probably the only place in the house where I could pull that off)? What else am I missing here?
Any insight is appreciated, I've come to learn and am keeping an open mind! This is our first build and my first dedicated shop, I'm sure that I will miss things but hoping to make sure I get the essentials covered.
Thanks in advance!
Thanks in advance!
