Found this in a Old Bolt Bin that I bought - What are they?
HKlassen
Moorhead, MN
I bought an old bolt bin from a farmer who was retiring. I found about 50 of these in one of the bins but have no idea what they are? Can anyone shed some light here? I included the quarter to give a sense of scale
srvctec
Central Kansas
I'm gonna guess some sort of die for pressing snaps or something similar, although there should be another part that these mate with. Maybe even just to dimple metal?
steaks&anvils
Colorado
OP said there were fifty of these. That is a lot of the "one side" of a die.
exmaxima1
Midwest
My guess is that it's the scrap slug from the screw machine that made the nuts. AFAIK you lose the small end piece that was held in the machine jaws, much like you would with a lathe.
The Tool Tyrant
Bonita, Ca. (San Diego)
Okay, I'm in :rocker:...I'm going with custom fixturing bushings. The bushings fit into holes on a fixture table and the part / weldment is attached to the bushing via a bolt or stud...that's my guess, and I'm stick'n with it!
matt_i
SE Michigan
They look like some type of early version of a nutsert but would need to flattened like a rivet instead of the tool system in place now.
I'll go with "machined part" something like where the original 2 threads in the base metal were stripping out so one cored out a larger hole and welded this in place and bam, new threads and several more of them.
larry_g
oregon
Skate track bearing hubs, could be for conveyor track in some farm implement such as a harvester.
lg
no neat sig line
1320stang
Edmond, OK
Are they all the same? or different diameters? I'm sorta thinking some sort of centering device for locating the center of holes for a gasket or something.
BFBOB
See post 10. Click the link - scroll down a bit and you'll find a chromate finished insert that's a dead ringer for OP's. Stands out from the rest because of its golden glow. No doubt, it's a weld-in threaded insert with a blind hole.
BlakeTheCarGuy
Roanoke Virginia
Maybe you could go back to him and ask lol. They look almost like mini bushing press things maybe for something small.
SuzukiGS750EZ
I'm going with some sort of self retaining nut.
Though, it could also be a replaceable part on something that wears frequently like a detent ball or roller type ball, such as on a folding frame lock knife.
