ICON wrench open end measurement
San Jose
Hi guys,
Does anyone have the non-flex ratcheting wrench set (antislip), or the antislip combination wrench set? If so, would you please be willing to measure the open end on a couple wrenches? I’m interested in seeing the tolerances. I have the icon flex ratcheting wrench sets and the tolerances are amazing. I’m seeing at most 0.1mm over.
I just purchased a milwaukee maxbite combination wrench set but was disapppointed when their tolerances are looser than the icons. Generally 0.2mm over. So, they’ll probably be returned. I was expecting more from them. I know I’m ****! But I cant afford Snap-on!
I really dont want to purchase the sets and return them if they arent great. It just feels wrong. Thanks for your help!
Oil leak
Home
I think your being a little crazy about tolerances. I just checked my Icon reversing ratchet wrenches (sae pattern), and they are .006 to .012 oversize. In metric that is .16-.27. In comparison my Snap on flank drive plus metric combination wrenches are .2 to .24. Your over thinking this.
San Jose
I appreciate that you took the time to measure. Thanks
I think snap ons can run a little looser because the open end doesnt flex when under torque. Great metal. Ive seen taiwanese open end wrenches flex a little... just enough to round off bolts if tolerances are loose. Thats why I’d want the tightest open end as possible with taiwanese wrenches
Ive had a bad experience with a rounded off fastener. It was a nightmare. Couldnt get a socket or box end on it because of its position.
larry_g
oregon
https://rtstools.com/the-best-hand-tool-sockets-in-the-world/
google iso 691 and you will find charts like the above, that is the standard. Having people measure their wrenches is un reliable at best. Look up the standards that your wrench was built to meet and see if it does. Then look up the standards for the fastener your applying the wrench to. You may be surprised at how wide the tolerances are.
lg
no neat sig line
GrantCee
Willamette Valley, Oregon
I think snap ons can run a little looser because the open end doesnt flex when under torque. Great metal. Ive seen taiwanese open end wrenches flex a little... just enough to round off bolts if tolerances are loose. Thats why I’d want the tightest open end as possible with taiwanese wrenches.
I don't get this. Instead of wasting time trying to figure out which Taiwanese wrenches are "best" based on dubious criteria, how about spending just a little more* than HF wants for the Icon product for a set of Wright wrenches — you'll get the tight tolerances you feel you need, along with Wright's renowned strength and open end grip.
Don't like Wright? Proto is probably in the same neighborhood. Either way, they'll likely be better than anything you can buy at HF.
*(14pc Icon metric combo set — $99.99; Wright 15pc metric combo set — $167.05 at Epstein's.)
San Jose
Is that really a “little” more? Seems like 67% more expensive.
Why is it dubious? If a wrench has a 0.1mm tolerance, thats a fact. To me, theres nothing dubious about it.
Thanks for the suggestion on Wright
San Jose
lg
no neat sig line
Thanks, Larry. Will investigate
Oil leak
Home
My Wright grip2.0 13mm wrench has looser tolerances than my Snap on
Fedwrench
Valley of the sun
I'd be interested to see if the Icon open end is different than the Milwaukee set you have since, both wrench sets are made by Infar. Infar also makes the Carlyle versions and the economical channellock version along with others. :beer:
dnschmidt
Phoenix, AZ
This is in fact a double edged sword. I've provided Eric O of South Main Auto many TOPTUL wrenches (made in Taiwan) and Eric loves them but from time to time he does have a problem with them in that TOPTUL builds their wrenches to very tight tolerances. Since he works primarily on rust belt garbage cars often the nuts and heads of bolts have swelled due to rusting and he can't fit the TOPTUL wrenches on to them. His Mac's on the other hand which are looser do fit. So be careful what you ask for as you might just get it.
San Jose
I have the icon flex ratchet wrenches which dont have an antislip open end. Just a regular open end. The tolerances are really good. Impressive really.
San Jose
Good point
Fedwrench
Valley of the sun
I believe the Icon flex head ratcheting wrenches are made by Kabo though. Is the a sealed brass screw on the edge of the ratcheting boxed end?
cherrybomb
Near Madison Wi.
I believe that you might also check the bolt heads and nuts for their tolerance.Sometimes the fasteners are the problem,out of tolerance. Us guys in the rust belt,have another problem.You'd be surprised sometimes how you have to substitute different brands to get the feel you desire.
Wakefield
Arlington VA (but would like to get out to country
I would think the Wright a good choice and cheaper than Snap On and probably better than the wrenches at H.F.
Anyone have any opinion as to the new Wright Grip (antislip open end) vs. the older one?
Cgw1984
Oklahoma city
Almost 1 and 3/4 times the cost isnt a "little" more, as noted. Wrights are great tools, but perhaps out of his budget. Idk that id recommend the icon either though. The wrenches arent getting amazing reviews.
