In this week of American redemption...some tools from other places.
Part 1: Amazon.de (manual) and .com (power)
Hazet Santastools 2000 set. This set is the first ‘advent calendar’ I’ve purchased, and that solely for the Hazet-branded "Rolplast" (Rolgear mechanism, made under license by Oplast in Slovenia) clutch screwdriver with bit storage.
The kit also comes with one of those bottle openers some people like but aren’t my thing, and some credit to their German “fan shop.”
View media item 107668View media item 107672View media item 107673
The screwdriver is pretty nice. Bit retention is magnetic and mechanical. Annoyingly, as on the new Felo you can’t just push the bit in and have the mechanical part lock in. You have to manipulate the ring first. I like the stubby bit-holder + extension concept better than the long shaft on Gedore’s rebrand of this screwdriver I have seen in pictures. Honestly the clutch doesn’t fare any better with loose screws than the PB Swiss or Felo ratchets do.
View media item 107669
The 3-wide bit storage makes for a thick handle, but it’s not terrible. With a few others, for a handle thickness comparison. IMO PB Swiss has the most efficient bit storage per thickness. If Wiha added a ratchet to UltraDriver - why haven't they ?!? - they would win.
View media item 107670
I suspect neither the bits nor the L-keys are German, given that the bottle opener is stamped as such but the other parts are only stamped Hazet. Germans stamp their L-keys. Screwdriver itself is presumably Slovenian.
View media item 107671
The US price of this set is truly absurd highway robbery (to be clear, I blame the importer not the retailers), and frankly even the German price of ~60EUR is a too much for what you get. At the US price the top of the case should be kitted out with 1/4” drive real Hazet sockets, not outsourced L-keys.
Other amazon.de/amazon.com purchases: Knipex pouch set, “Gedore” Rolgear x Olplast clutch screwdriver, Wera VDE set.
View media item 107657
Neither Cobra nor PW are a mystery to anyone here. I didn’t realize it at order, but this set is actually different from the one I bought from KC Tool. The PW is the same, but the Cobra is smaller and the pouch is actually smaller too. I meant to get the same one, so the kids’ toolboxes would have the same stuff. Oops!
View media item 107665
View media item 107664
Gedore “Rolplast” (Rolgear design, made under license by Oplast) clutch screwdriver. I’ve seen a version with the same handle as Hazet Santastools but a longer shaft pictured, but not available for purchase from a vender who ships to the US. That one also seems inordinately long. Hazet's Rolplast with bit storage is is better. Seems pretty nice, though I still like PB Swiss and Felo ratchets better so far. Gedore is open about the origins on the shaft.
View media item 107658
Wera swappable shaft slim VDE set
I picked up the Wera set because it was cheaper than I expected, and I figured it could replace a set of Wiha VDE screwdrivers with similar utility but lower weight. They are as expected, which is to say no complaints after brief use. I’ll replace the useless voltage tester with a second handle, and add square drive shafts.
View media item 107660
All but the smallest slotted are the thin shaft/flush insulation.
View media item 107659
Bosch brushless 12V Flexiclick and drill/bit case.
I bought this primarily to add a hole to a cabinet for a power wire grommet. My Fein 18V drill was too big and had too much nose to get the hole near the back.
View media item 107662
View media item 107663
So far I like the drill, but the case is disappointing in one respect - normal bits don’t fit well. I was planning on replacing Bosch insert bits with Felo slotted/PH/torx and Wera hex/square/ASSY (keeping only the “P2R2” bit, which combines PH2 and SQ2, so should fit combi screw heads better in theory), but normal bits don’t fit in Bosch’s bit racks fell. Power bits fit OK.
View media item 107661
Knipex Cobolt (spring-loaded + gap jaw)
I wanted a second Cobolt (IMO this is the best configuration of the tool, so I didn’t see the need to try a lesser variant), so I bought this one. Again, nothing unfamiliar to most of you. Just a useful, solid tool. If Knipex were just Pliers Wrench, Cobra, Cobolt, and Crimp System they would probably still be one of the world’s best tool companies.
View media item 107666
View media item 107667
