Between 485 & 705 SQ/FT Mid-Century Moto Mecca Makeover
gearhead1960
Hmm, that's a tough one to parse. I'll take it but hope that I'm not as tragic.
G
I had the cliff notes idea of Howard in mind, "a moral man and a practical man. His strength of character is demonstrated throughout the story. He is fully committed to the artistic integrity of every one of his designs, and he takes a laborer's job in a granite quarry rather than compromise on the smallest detail of his building.":beer:
zmotorsports
Northern Utah
Well done on the fan repair Gregor.
I've had a few of those precarious milling setups as well and I always seem to breathe a little easier when completed.:D
Sham
Antibes, France
Thank you for the details on your fan collection!! Damn, I very might use that first picture of your collection as a background on my laptop!
I've been looking for a Roto-Beam ever since you mentioned them first, but I've been unable to find one yet. I'm on the wrong side of the Atlantic it seems, and I've not found anyone willing to ship one accross the pond.... yet.
sakurama
Portland - the cool one.
And now everyone here is hunting eBay for a roto-beam... hahaha
There's one on there now - don't get it. The later ones had black plastic/bakelite blades and a tightly wound and boring cage that prevented you from getting a finger in there.
Too safe - not that interesting.
The small one with the bullet back and cast aluminum base and frame is my favorite. Older ones have an exposed motor and they're nice as well. Any of them with the aluminum blades are super cool (so to speak).
I have a search always running but honestly there's not many anymore. I've found and secured all the ones that I want so I won't be bidding against you guys. I think this is an example of how ebay has spoiled the ability to find great deals. Anyone can look up something and then they see what it was sold for and they have a sense of the value.
Now we only find great deals when people can't spell. :dunno:
Tomorrow I'll take a photo of the bigger fans.
Gregor
sakurama
Another small project to tick off to help keep your mind off current events.
I needed a work stop on my cold saw. I've found I use the one on my mill way more than I expected to and I've always wanted on the Trennjaeger. The Festool rail works for long parts but most of the time I need smaller parts so a simple work stop seems like a quick evening project.
I made it pretty quick from scrap and didn't take many photos. After it was done I thought I should at least clean it up a bit with the face mill.
It's not important to the project but it looks nice.
I have a small collection of quick release adjustable threaded handles that I like to use instead of a bolt or a socket. Having to find a wrench to adjust something is a real time **** and inconvenience.
So this is the sort of thing that I can do after the kids go to bed and it's too dark to work outside. It beats listening to the news and it is a small step to making the shop function better.
Win win.
Gregor
zmotorsports
Northern Utah
Nice job on the stop Gregor. I also like those spring loaded threaded handles and have used them on various other projects.
I want to make a nice work stop to replace the cheap plastic one on my Baileigh horizontal miter head bandsaw but can't seem to find the time. The plastic one works but looks cheap but it's hard to make time to replace something that's working when there's more pressing projects.
After seeing yours I may have to try and fit it into the project lineup.:D
sakurama
Thanks Mike!
I'm sure you heard the same thing I did growing up (mostly on the ranch): "If it ain't broke - don't fix it!"
There's a lot of wisdom tied in there and clearly that did not stick with me. But I will drag out that trope when I'm being lazy.
Gregor
bunks-tj
Manassas Va
a gravely bush hog just showed up in my facebook market place as an item i might be interested in, I don't know how it knew, but I blame Gregor.
bdbecker
Iowa
...So this is the sort of thing that I can do after the kids go to bed and it's too dark to work outside. It beats listening to the news and it is a small step to making the shop function better...
Its those projects that add up to make a world of difference down the road. Nice job!
sakurama
Short shop update!
This burned knob was on the Clausing Drill Press. It's for the crank that raises or lowers the head over the table. While functional it's not pleasant to use or look at.
Let's fix that.
The axle or shaft was peened in place so I ground it flush and pressed it out.
I grabbed a scrap of 1" 6061 aluminum rod and through drilled and and turned down the end to about the same as the original handle. Then I just sort of Etch-A-Sketch'd the rough shape of a knob. I have a Radius turning attachment but honestly it's a pain to set up and use so I don't bother. I should sell it. This method of pecking away with both X and Z handles is sort of fun and since I'm not trying to match a print there's not much to worry about.
I then used a couple of files to smooth the rough faceting of the knob.
Then some sandpaper to further smooth it out.
And then some Mothers Aluminum polish...
And it's always magic when you polish something in the lathe. I didn't try for perfect but it's always surprising how shiny it becomes. I suppose I could have worked through a few grits on sandpaper but this is a quick thing - something to knock out before bedtime and after dinner.
I cut a relief for the head of the screw and pressed it back into the handle. I know you're expecting me to refinish the handle but I'm not opening that can of worms. You refinish one handle and suddenly the whole drill press is torn apart all over the shop. Nope, I'm preserving the original patina.
It suits the machine and matches the polished aluminum knobs I put on the feed handle. Now I need to get this dang drill press off the welding table...
Gregor
E12-535iTurbo
The Netherlands
I see what you did there: You purposely blurred the drill press and specifically the handle with the new knob on. Out of our sight is out of our mind. But blurring it for us doesn't work for you. You will still see it. I'm giving it three weeks before you take it apart. Most likely you already did :)
sakurama
Damn! That looks great.
The two things that making it easier to polish is decent hp - at least 1-1-1/2hp to prevent bogging down, and then longer shafts that allow you to maneuver parts without hitting the motor. You can get shaft extensions.
Nice work!
Gregor
alfazer
N. Ireland
Nice work on the handle but I get the shivers when see a cloth near a lathe in case it catches and grabs you. Try a paper towel for the polish.
sakurama
Yes, that's true. I wouldn't do that with a chuck but with the collet closer there's not any edges or things that could catch. Still, it's good advice. Comfort and complacency are the things that really catch you out. I try to avoid them.
Gregor
sakurama
Well there's a couple of new additions to the shop. One more exciting than the other but that one is for later. Today is about a Craigs List find - my first Vidmar cabinet.
My search for a Vidmar finally pinged a week or so ago. It showed up in Seattle and was $400 which seems to be a good deal. If you spend much time in these forums reading about the Lista/Vidmar cults you'll know that the going rate for these is about $50/drawer so this would be a good deal.
The reason these are in high demand is that they can hold a lot of weight - like a crazy amount of weight. Each drawer is rated to 440lbs so theoretically this cabinet would hold... 2640lbs!
The drawers are heavy and the slides are solid and they run on big bearings. It's perfect for holding your liquid mercury collection. Remember playing with that in chemistry class? Back when no one followed any real safety protocols beside glasses? Good times.
But first, since I wasn't a fan of tan, I gave it a quick clean and sand and broke out my traditional machine gray enamel.
I wasn't going to completely take it apart but I did remove the pulls.
And I removed the emblem by hammering a pair of utility blades through the adhesive foam holding it on.
My quick and simple roller job turned out fine.
My plan, after looking at a few options, was to move the band saw over and stuff the Vidmar between it and the Bridgeport and that way the drill and mill are close to each other. They're tools you generally use together and they share a lot of the same tooling. Well, drill bits. But still they are nice to have next to each other.
The trouble is that to get access to the belt drive of the bandsaw would be near impossible without pulling it out so it seemed to make sense to put wheels on the Vidmar. To do that I needed to get rid of the "feet" or runners on the bottom.
To do that I needed to find the spot welds and drill through them - that tiny little circle is the spot weld and there were 6 per leg.
It was an ugly job to get them off but it would have been too tall to add wheels otherwise.
I gave it a very quick single coat of paint.
The casters I rescued from a commercial refrigerator that I had in NYC and I bought them off McMaster and they were rated to 3-400lbs each so they should be sufficient. Not overkill but adequate. The drill is 450lbs, the cabinet is 250lbs and then whatever you fill it with. Very quickly it will get to 1000-1200lbs.
To reduce gouging the top and spread the weight I cut a piece of 18mm baltic birch and screwed it to the top.
While I considered trying to MacGuyver a way to lift the drill press myself I got smart and called Scott who's sister was visiting - thanks for the help Hannah! We tipped the drill back and forth adding 2x4's until we got it to the height of the cabinet and slid it over. Sorry - I only took a single photo.
The drawers have dividers but not a bunch so it remains to be seen what I'll put in it. A new cabinet throws your shop organization into chaos with the promise of a better future - but you have to figure that out.
Pushing the empty cabinet with the high and heavy drill press was scary. You don't want to move this so the wheels are maybe not a permanent solution. Once there's a few hundred pounds of stuff in the cabinet it will be much better balanced but I consider the wheels more an emergency option than a convenience.
The drill press is a bit higher than I'd ideally like but it's not bad. I'm going to live with it for a while before I make any choices. For now I'm going to start to figure out what stuff should be in it and how to make sense of all this new storage space. Those bottom drawers are begging to be filled with lathe chucks and bending dies!
Gregor
Toolfool
Tallahassee, FL
First time seeing this thread. I spent all day yesterday reading from the beginning (I know, get a life) (I was waiting for an engineer who said he'd call when he was headed my way. Never called). Your approach to your projects is like mine ..... "If you're going to do it, do it right." You do some outstanding work. I was in construction for 35 years (the last 30 in WA. Coulda helped on your house). Before that, in NY. Wonder if our paths crossed somewhere. Before construction I was in camera repairs in NY area from 1974 - 1986, Nikon, Canon, Hasselblad, Bronica, Mamiya, etc.. Had shops in Long Island, Manhattan, Atlanta, Houston, and Pompano Beach,FL.
I'll be following from here on. Would enjoy sharing a cold one some day.
WoodsTruck
Nice find.
I have big feet so I typically try to index casters back under the cabinet once in place. First so I don't kick them (as often) and secondly so the cabinet can roll straight out when the time comes.
VMX42
Sydney, Australia
I'm with E12-534iTurbo...I look forward the the forthcoming drill press restoration series...
Come on Gregor - you know you want too!!! ;)
VMX42
Sydney, Australia
Kids...
https://photos.smugmug.com/photos/i-XHpnB2k/0/bfd662a0/X2/i-XHpnB2k-X2.jpg
We finished the handle and he carried it with him everywhere and slept with it at night and could not have been more happy. I don't know how you lose a giant aluminum sword. Nonetheless Ben, Tammy and Wyatt came over to celebrate and our neighbors managed to pull off a creative socially distanced trick or treat celebration for the kids which was nice.
If we find the sword I'll post a photo but I suspect that, much like our colonial house, it is lost to history and we have only the memory and maybe a few photos.
Okay, I have a few more things that I'll try to catch up on today and over the next few days...
...the big question...after the missing sword...IS...DID THE BLACK KNIGHT finish with all his limbs intact?
The world needs to know???
Kriesel
Afton, Minnesota
Gregor
You could try using appliance casters or machinery skates instead, and it would lower it quite considerably, and still allow for pulling the cabinet straight out when needed.
Example:
https://www.northerntool.com/shop/t...ZxARHCOL4C8V4LCbFThoCslIQAvD_BwE&gclsrc=aw.ds
sakurama
Kids...
So ironically Lucas found the sword in the pantry near the printer. How or why it's there is beyond me but it came back. So now he needs to be a knight again next year.
Gregor
PS - No, I'm not restoring that drill press. It's in fine original condition. I appreciate you guys tempting me but I have projects on top of projects. Literally.
Choirboy
SE Iowa
Oh good, I'm glad the sword was found. I figured he had set it down outside and another kid decided they needed it more. Yes, it was just a toy, but it was a toy made by his dad, and that stuff is meaningful. I'm glad it was found.
gearhead1960
Someone in the household, who chooses to stay silent, found it or snatched it when he wasn't looking because either he was not using it appropriately or he set it down and didn't remember doing so. That said person then put it near the printer, knowing it would be found eventually.....:lol_hitti
sakurama
Your theory is extremely likely and I'd hazard it's something I'd do but didn't in this case. At least I don't think so. I have been known to hide the kids iPads so well that it takes me a couple of days to find them...
If there's any disappointment in my children it's that they're not nearly as sneaky as we were as kids. I mean, finding halloween candy wrappers in their bed? That's just sloppy. As I kid we'd steal cookies and then space out the remainder so the package looked untouched. Kids these days.
Gregor
gearhead1960
Gregor
I had to laugh at that statement. I used borrow my parent's car to drive to high school after they went to work. I would chalk the driveway where the tires were positioned so it would be in the exact place it was when I parked it after driving it. My dad was very **** (I know where I get it) and would notice if it wasn't parked "correctly". I don't believe they ever knew, or they just never let on they knew. I'll believe the former :lol_hitti
laralovesmoka
Westcliffe CO
Happy Birthday Gregor! My earliest memories of you are the three of us sitting at the white linoleum kitchen counter and you drawing race cars. I can still picture them with their cool designs and perfect lines. And then there were the Testor cars you built in your room, the little bottles of paint, decals. You even had that racetrack. The more things change the more they stay the same. Today I think about how incredibly (talented, yea yea yea, we all know that) patient you are. You are a fantastic teacher with seemingly endless amounts of patience when I screw something up, crash a bike or ask for the zillionth time which order to shellac, sand, poly. We’re lucky to have you in our lives. Happy Birthday! Love you!
cad70
NE
For those considering an older Lista or Vidmar cabinet, double check how well the drawers open/close. The slide bearings are no longer available for anything made in the late 90s and earlier.
Clark
sakurama
I recently got a PM from a follower named Kevin about knives - something he rightly thought I might have some opinions on and I've been considering doing a post on that subject but it's one I haven't tackled because it's rather controversial and, like politics, people are pretty entrenched on their views.
But it is something that I am really into - knives are the most elemental tools and I'd guess that if we gathered up all the ones in the house we'd have maybe three or four dozen. I have at least a dozen pocket knives.
Here's a link to Kevin's thread.
Knives are the original tool, right?! I'm always amazed at the depth of knowledge on this site so figure I'd see what you all have to say vs setting up a new account on Chowhound or some other food related site.
I want to get my wife some 'good' knives and given I know nothing about knives I figured you and your depth of knowledge on almost any tool likely would
Any advice on what to look for vs not?
Looking to spend ~$300 for a nice set.
Let me know your thoughts!
There's some good thoughts but I think that the whole knife thing tends to go in the same vein as the whole, "what's the best camera" question and that question and the knife question need some heading off at the pass.
First I want to address the elephant in the room - the "set".
You don't need a set. Don't buy a set. The whole "set" thing is a marketing scam designed to trick you into spending money. You need only two knives in your life: an 8-10" chef's knife and a paring knife. Don't believe otherwise. I used to think that a bread knife was part of that mix but that was before I learned how to sharpen a knife. Bread knives are not needed if you have a sharp chef's knife.
Okay, some history. Just so you know where I'm coming from.
My dad always sharpened knives with a whetstone. I tried and never seemed to have his patience or skill and was always impressed when I'd buy a new knife because that was as sharp as it would ever get - it was on a downhill slope with me as it's owner.
I was married before Judiaann to the god daughter of Jaque Pepin and her father was an amazing chef as well - Jaque and Jean Claude were the chef's for François Mitterrand, France's President. When I first met Jean Claude he invited me into his kitchen and asked me to chop some onions for him.
I did it all wrong as you might imagine.
From Jean Claude and Jaque I learned knife techniques and basic cooking skills. I once won a guacamole competition between the three of us at Jaque's house in Mexico. That's my one and only culinary claim to fame.
Fast forward to years later meeting Judiaann who worked at the French Culinary Institute (an unrelated but odd coincidence). I took a knife skills class with her and realized that my knives and hers really weren't that sharp and perhaps a whetstone wasn't the answer I was looking for. Thus started my quest.
I don't remember how I met Chad Ward, most likely through friends in the culinary world, and he'd just written a pretty great book about knives. I read this book and finally decided to an actual knife sharpening "system" instead of abusing my knives with my incompetence.
Let's circle this back to the set. Buying a set of knives is like buying a camera and a bunch of cheap lenses all at once in a camera bag. You don't buy a set of houses or a set of cars (well, some do) you do the research and find the right one for you and then spend the money on one good one. That bag of glass does not make you a photographer and that block of knives isn't making you a chef. You're better served by getting one great lens and learning it.
The whole discussion of German vs Japanese steel is a lot like the pontificating of Leica vs Nikon in that very few people will ever be able to see or understand the differences and how sharp your glass is really isn't a question if you can't focus.
So let's focus for a minute on what a knifes job is so we can defuse the steel question.
A knife is a piece of steel that's been hardened and sharpened in order to create an edge that will cut.
That's the general definition that I'm going with. The minutia is that steel is not one thing so your edge should not be either. A very hard steel can be sharpened to a very steep angle but then it risks chipping. A more forgiving steel can withstand chipping but not hold up to a steep angle. It's a compromise.
Understanding this compromise helps you understand that there's no "perfect" steel or "perfect" knife. This is the main thing to understand and it's a lot like the camera discussion - the camera is a tool and understanding your tool and it's limitations is how you become better.
This is my third (and last) knife sharpening system. It's a Wicked Edge Pro system. Buying a jig to sharpen your knives isn't cheating. That's what I thought at first. If I practiced I'd eventually get a really sharp knife with a whetstone. I thought that for at least 10 years and never had a sharp knife. The day after buying my first sharpening jig I sharpened my first knife to a scary edge that was as sharp as any new knife I'd ever owned and I've never looked back.
The basic premise of a knife sharpening jig is that you hold the blade at a fixed angle to the stone and you grind the steel with progressively finer grits of abrasives at that set angle thus refining that edge. While it might be possible to teach your hand the difference in feel between a 17 degree and a 21 degree angle it's not something I want to spend my life doing. For the same reason I don't want to memorize phone numbers - I can have a machine do that for me.
So I'm going to take you through my process.
This is a Shun "Kramer" and I put that in quotes because I've never been impressed with this knife. It's felt like the combined sell out of two names that independently were great but combined to make a compromise no one is happy about. This knife is brittle and chips a lot.
Through the loupe you can see these micro chips in the blade. In a perfect world we'd have a knife for boning chicken, one for cutting vegetables, one just for tomatoes but the reality is you probably have one favorite knife and you do most everything with that.
This is the same as the camera advice - buy a good knife that you really like and then buy good method to keep that knife sharp. Keeping it sharp is more important than what the steel is or where it's made.
When you have a knife sharpening jig you suddenly have the thing that allows you to achieve perfection in a blade - repeatability. There's a reason mills have dials with numbers and DRO's that measure into the thousands. Our ability to repeat and measure a procedure with accuracy is what creates a better result. So it will not surprise you that I keep a log of my knives and how I sharpen them. This is how I match the angle of the edge to the steel. I tried to sharpen the Kramer at 17 degrees but it hasn't held up so I've moved to 19 degrees.
To determine the angle of a new blade (or check an old one) I'll use the loupe to check for cracks and the sharpie to draw a line on the blades edge.
Then I run a smooth stone along the edge at the angle I want and see if it takes off all the sharpie or if it leaves it at the top or bottom.
Referring to my spreadsheets notes means I don't usually need to bother with this step but for a new knife I like to check it, adjust the angle and figure out what I'm starting with.
The basic kit I think comes with two or three sets of stone - or in this case diamond impregnated sharpening steels. The far right and left are really optional. I rarely use the 50 - it's way too coarse - and generally will start a regrind with the 100.
The process is pretty basic: clamp the knife in the clamp, set the angle via the lever (or whatever method you have) and then begin moving the stone along one side of the knife until you have developed a burr on the opposing side.
The movement isn't too critical because the jig is maintaining the main essential angle. I'll go up and down and then vary with some strokes angling down and forward and then down and backwards.
But the burr is essential. Here's your deep dive into what the burr is: The Science of Sharp
As you get closer to achieving an edge the fine part of the steel will begin to bend over on the opposite side that you're working. It's very small and not something you can see save for the Science of Sharp link above.
But you can feel it. It feels like a rough edge or a single line of micro velcro that catches your skin as you swipe up the blade from the spine to the edge. Your goal is to get your blade to the point where you feel this burr along the whole edge on one side and then to repeat the process on the other side. If you don't get the burr you haven't sharpened your blade to its edge yet and you won't get a sharp knife.
The process is to raise a burr on side one with the 100 grit and then the other side. Then move to 200, continuing to raise the burr on each side before you move to the next grit. I quit checking for the burr when I get to 400 at which point I just alternate strokes. The burr still exists but it's become so small it's hard to feel. From 400 up we've established the geometry and now we're refining the edge. Lather, rinse, repeat with each stone getting progressively finer.
The whole stropping thing never made sense to me because it turns out stropping a dull blade doesn't do much. A sharp blade however can really benefit. You don't need anything fancy. I bought a cheap leather belt from Goodwill, cut it in half and glued
it to both sides of a paddle I made from baltic birch. You can even see the belt holes. On one side I put a very small amount of Mothers Aluminum Polish - that amount shown is way too much but will last for the next year.
Stropping is just further polishing the edge and getting rid of the microscopic burr that's left after your final stone work. Draw the knife away from the edge at the same angle as you sharpened it at. It's not critical as the leather has some give. After a few stokes on both sides of the blade flip the strop over and do a few on the back side which is just leather with nothing on it.
You can shave your arm but a newspaper is a good indicator of a job well done. By virtue of it's flimsiness it shows off a good edge because your blade should glide through the paper with zero resistance.
A truly sharp blade will cut into a curved fold of paper with no effort.
If we come back to this photo my pairing knife is a cheap German blade. I'd like and need a good paring knife but honestly only Judiaann uses the paring knife. The bread knife I've not used in five or six years and even Judiaann quit using it once we had consistently sharp knives. The middle knife is interesting. It was a serrated Shun tomato knife but it became dull as all serrated knives do so as an experiment I sharpened it to an extremely steep angle of 15 degrees with only the 100 grit stone leaving a very steep and rough edge. It can slice transparently thin slices from a tomato because the rough edge helps tear the tough skin of a tomato - it's a single use knife that is very nice to have.
This Misano has great steel and I keep it razor sharp at 15 degrees but mostly only use it for vegetables so I don't abuse the super fine edge. I also don't go higher than 800 grit because the tooth left works like the tomato knife - micro serrations that bite into the thing your cutting - which, let's be honest, is probably onions. I think onions make up about 70% of all the cutting in the house. Well, onions and garlic.
The Shun Kramer is the all around knife. I'll take it to a razors edge and it lasts for maybe a month. Unlike my cameras where my Leica is my favorite tool I don't have a favorite knife. I'd like a damascus knife, I'd like a custom knife and I think something shaped like the Shun Kramer is a good shape but with better steel and a concave hollow grind to release food would be awesome.
At some point I'll try to make my perfect chef's knife but for now I'm content with these because they're extremely sharp and that's much more important then where they came from or what steel they're made of. I hope I demystified some of the whole knife thing. Get a good knife that you really love to use and hold. More importantly get a good system that allows you to perfectly and consistently get a super sharp edge.
Gregor
sakurama
Awe, thanks Lara!
G
cad70
NE
[/IMG]
Perhaps another opportunity to create your own partitions, or go the schaller route. :)
My Gold Rush trailer has 2 Lista cabinets, and it came with a gazillion partitions that I need to arrange.
Clark
Choirboy
SE Iowa
I'm not a great chef nor a machinist, but Gregor is right on about keeping a knife sharp is more important than what knife it is. I keep a strop near the kitchen so I can touch up edges every other use, so I can delay going back to the water stones a little longer. Also, NEVER put a knife in the dishwasher, the detergent used means every time you put the knife in the dishwasher it is effectively sandblasting the sharp edge right off your knife. Also never use a ceramic or glass cutting board, it is harder than steel and will bend the sharp edge right over.
I also completely agree that a knife set is a waste of time. Personally I like three knives, a big chef knife, a short pairing knife, and a long pairing knife that can do double duty as a boning knife.
To more directly answer kwoody51's question, Cook Illustrated/America's Test Kitchen consistently rates this knife as top performing: https://www.webstaurantstore.com/victorinox-47521-10-chef-knife-with-fibrox-handle/35347521.html
It used to be cheaper but all the press from ATK has made them realize they can up the price. You'll notice you can get the same knife in a 12" size (bigger than most home cooks like to use) for less money. Unfortunately it isn't very **** so makes for a not very cute present, but it is extremely practical. I do see that Victorinox also has wood handled versions, maybe they are just as good but a little nicer looking?
Bob Heine
Boca Raton, Florida
Thank you for the knife edge present. My knife collection is completely out of control. Like you say, I really only use a couple of knives. I recently bought a set of kamikoto single bevel Japanese knives in the hope they would be my salvation. I can get a sharper edge on them because I can't overdo the edge on the opposite side. Even with the three-blade set, 99% of the time I use the paring knife and the cleaver. Being right-handed, these knives work really well for me.
rk_tek
Bella Vista, AR
Once again, Gregor comes in and drops more knowledge on a subject than any one man should possess. Just last week my wife and I decided it was time to retire a set of knives I've had for 15 years. They live in a plastic voodoo doll 'knife block' if that tells you anything about the quality. I've kept a usable edge on them through the years and they will be sold to someone less discerning.
We did buy a 'set' of 5 Wusthof Classics. The main reason for a set is that my wife will use every knife in the block in preparing a meal instead of washing one knife in between meat and veg. Last night she used 4 utensils in preparing a microwaved potato. 3 or 4 years ago my brothers and I bought my sister a similar set of knives. They have been abused and poorly blunted on the steel. I refuse to do any knife work in her kitchen, but she happily keeps mashing slices of tomato with them. I'll be looking into the sharpening system you have. i've had the ceramic rods that come at a preset angle and have never been a fan. I have been using a whetstone or diamond impregnated stone for 25 years or so and can keep a decent edge on things, but it is not as precise as I'd like. Time to grow up and sharpen to perfection.
Also, Happy Birthday.
fartymarty
Fort Worth
So now I need a $400 knife sharpener system and a spreadsheet instead of a sharpening steel...and a strop instead of a honing steel? :headscrat:willy_nil
Well for present, I think my Sam's Club chinesium white plastic handled knives will work for my lacking culinary skills and the cutting of my stew meat. However, I'd like to hear more about the "knife skills class". I'm assuming it was a lot more involved and useful than just making tomato roses and pine cone looking radishes right? I have no idea, but I'm assuming that the primary benefit is learning techniques that blend safety and speed? ..or is there a lot more to it that actually allows you to make food taste better and cook better just by how you cut it? To be clear, I'm not asking you to teach an online class here, but perhaps reveal some of the course syllabus?
Many here envy your skills and abilities (as do I), but really I just mostly wish Lara was my sister.
Happy Birthday Gregor!!!:beer:
