Old Man Roger
I'd drive it.
Carb work on the hot rod. 850 Holley mechanical secondary’s that is wanting more fuel out of the hole.
Made a mess.
Finally welded in a patch panel in the floor of my F150. Good grief, I really need to practice welding sheet metal if I’m gonna do anymore body myself. The welds look like straight trash. Didn’t realize I didn’t have enough gas flow at first and kept blowing through as well as having the puddle turn into a little mountain. It’s watertight and has been painted but I’m far from proud of it.
Discovered I had a screw loose, tightened it...
Although it wasn't quite that simple.
Guess which Allen wrench was missing from the set? (found another)
Took a while to find the blue Loctite, even though I had a fairly good idea which tool cart it was on.
Then decided the general shifter area needed a clean up & the peg could use a cleaning.
Are you accusing him of having chicken strips on his tires? lolThere's something wrong with those pegs. The tips aren't all ground off on a bevel...
Tommy
That looks suspiciously like the base for my little Beaver table saw. I'm going to guess a Rockwell - Beaver jointer?
I've been bustin' **** all summer but have been slack on sharing my Powder **** here lately.
This small block dress up package is for an honored 70-year old Veteran in Kentucky with a '79 Dodge Warlock II.
These always need a lot of metal work. Candy gold and flawless gloss black are typically tough to pull off, especially on multiple cast parts, so I hope he is as happy with it as I am. There's a touch of flake in all three powders (the gold needed a shiny base) ... if it was sunny today they'd be outside for full effect.
Happy Dance!! << wiggle wiggle >>
Have a fabulous weekend and a happy Thanksgiving everyone!
I suspect the answer will be "If you have to ask, you wont understand"StokeF, is there a reason you are polishing the face of a ten Lb sledge?
Everyone needs a ported and polished snow blower..guess what I did..
worked on another snow blower!
this time it was mine. Getting an early jump on it this year.
My other blower with the OHV motor - might get treated to some head mods. I might even dust off the flowbench for that.
