Sasquatch912
I've been debating about buying a belt drive pressure washer later on but right now I am going to have to wait. I have an old Generac pressure washer that the pump failed on and I am debating about taking the hose and nozzle and hooking it straight up, somehow, to my deep well. The deep well pushes out ALOT of water as I also have a 1 1/2 inch pipe. I am trying to figure how I can run this pressure washer hose to it OR if I need to just get a big hose that is attached to the cut off valve on the well and get an adapter to hook up the pressure washer nozzle to the hose.
I know I may not produce a lot of PSI but my GPM should be higher than my old Generac at 2.3 GPM.
My plans is just to use this deal to clean up my farm equipment and trucks.
Think it will work?
Think it will work?
