I'm currently building a house. I have a 14x30 basement storage area that is under the back part of my garage. The garage slab will have hydronic heat, 2" foam board under the slab, vapor barrier under the foam, then precast concrete. The storage area ceiling is the bottom of the precast concrete.
I'll have hydronic heating in the basement storage area too, it's really just a storage area but I want to keep it above freezing (probably 45 degrees). The garage floor above will always be kept at or above the temp of the basement shop.
So, my question, should I bother with insulating the ceiling (bottom of the precast) in the basement storage area? Or would that be a waste? The walls in the storage area will be insulated.
