Weld table set up
Brno8x57
Maryland
I just bought two 36x48 metal table that I will repurpose for mobile workbenches. One has a 3/4 inch plywood top flush with the edges. I want to use
The other for a weld table; hobby level use. Ideally table tops will be flush to each other to have 8 feet work area.
Should I drop a 3/8 in plate on top? Any thoughts appreciated.
I am restoring a car but enjoy welding, have mig and will likely add plasma cutter soon.
I like to roll the station outside so will be adding casters.
The table has frame for a drawer.
Looks to be 1/8 inch steel.
quadrcr87
Travelers Rest, SC
I really like that table frame design! The boxed in top looks like it will support a plate really well. 3/8 should be plenty. Just be careful not to put a lot of heat into it when you weld it on. I warped my 3/16 top when I welded it to the frame with multiple 1” beads. Bolting the plate on with some countersink bolts could be a good option too.
Brno8x57
Maryland
Can I just drop it in? It was built with a lip to hold 3/4 inch plywood making a flush surface
rvieceli
Illinois
If you want to just drop the top in, I think I'd shim it up so that it sits slightly proud of the base. You really don't want to have a lip on the edge. So maybe use 3 pieces of 1/2 inch flat bar to shim it up. That would make it proud by an 1/8 or use 3/8 for even. I'd put a piece down each long edge and one in the middle. Top is going to weigh about 180 pounds so it should keep them in place.
Ron
Will S.
The First State
I would put a piece of 1/2" or 5/8" gypsum board down first, then the 3/8 steel plate on that. As others have said, some steel support vertical flatbar or angle iron for additional support across the center.
Brno8x57
Maryland
What is the gypsum board for? Drywall?
swavescatter
I'm guessing for guaranteed flatness. I just built a welding table with 3/8" thick 4'x8' and it had some shape to it. Probably need to go at least 1/2" or more to avoid that, or find a way to make it lay flat...
