Colin Len
A couple years back I happened across some Armstrong VCT for cheap so I bought enough for my garage but haven't gotten around to installing it yet. I'm looking at a "garage refresh version 3.0" that may happen early next year so was making plans to lay the VCT at that time. Then, today I got an offer to buy some used silver and black RaceDeck for $1/sf and am considering going that route instead. I'm interested to hear everyone's opinions on any pros/cons between the two. Are there any other factors I should be thinking about here? At the moment I'm pretty much stuck dead in the middle with this decision. I'd kinda rather not go out and spend $400 on new flooring when I already have something usable but I also realize that in the long run I'll kick myself for letting that stop me if it's the right decision. My thoughts so far:
VCT PROS
VCT CONS
RaceDeck PROS
RaceDeck CONS
Here's my garage floor now - 75yrs of who knows what sorts of dirt, oil, paint, debris... Total it's about 330sqft and is in fairly good condition - no cracks or uneven areas but it does have some 1/4"-1" pits in the surface in some areas. I will likely be getting rid of some or all of the blue cabinets so that isn't necessarily a big design cue going forward.
Here's the VCT I have already. It's white with a sorta blue fleck to it and I picked up a couple boxes of the blue as well in case I wanted to add an accent (there's no enough for a checkerboard pattern).
I'd love to hear everyone's thoughts and what other things I should be thinking about here to help make my decision. Thanks!
VCT PROS
- Durable
- Can be sanded/refinished/polished
- Cheap/Free (I already have it, and only paid like $80 a few years back)
- I like the idea of a lighter colored floor for aesthetics and light reflectivity
VCT CONS
- Would require floor prep - filling pits in floor at a minimum
- If there are any moisture issues with the slab this could be an issue with the adhesive over the long run.
- It's glued down - so not easy to remove if I ever wanted to do something different.
- Possibly tough to keep clean since they are a light color - e.g. tire marks from my sticky track tire. And likely harder to clean than Racedeck. Also, this VCT is a commercial/industrial version that has a little bit of a rough finish for slip resistance. So I worry that rough finish may hold dirt easier.
RaceDeck PROS
- Easier to install
- Gives a softer, more insulated feel to the floor
- Can be removed fairly easily, even resold possibly
- Grey is a good balance between not being too dark but also still hiding dirt/debris compared to white
- Based on the quantity that the seller has I could do solid silver, silver/black checkerboard or silver center with a black ring around the outside.
RaceDeck CONS
- Possible buckling due to heat from the sun. I read this a couple times here but not sure how much to worry about it. My garage door faces East so it would get the morning sun. I usually keep the door closed but not always.
- Possible shifting - I had read here about people's tiles shifting forward ever so slightly due to parking a car.
- They are the diamond tiles which I'm not crazy about since I generally hate the look of diamond plate. I'd prefer the coin pattern but beggars can't be choosers.
- The diamond texture also seems to be not as ideal for rolling things around on vs the coin pattern.
- Grey/silver is maybe kinda boring.
- Probably doesn't stand up to welding as well. I won't be doing a ton but it will happen occasionally. Most of the time I'd try to weld outside but that won't always be practical.
- Unsure how solid a bench would be if it's on top of the race deck. I'm taking about a bench that you'd use to really wail on things, something you didn't really want to have any "give" to it.
-- you should definitely go with RACEDECK
