KSJeff
I've been looking for ways to organize my sockets for quite a while now. I've tried all kinds of brands and I'm always going back to those pin holders on the portable tool boxes like these.
In an effort to recreate, I've tried setting nails in the back of thin plywood and painting them with plasticoat. Didn't like the result. I've also thought of repeating the same exercise with some sheet metal and nails and that may ultimately be the direction I go.
Recently, I started looking at stud welders and the cheap dent puller/stud welder combo from Harbor Freight which will weld 3mm studs. I haven't looked at the gun yet, so I'm not sure I can gets studs close enough to make this work but it looks like a reasonable solution.
If you wanted to recreate something similar to the above that you could mount horizontally or at a 45 degree angle, how would you do it?
