Good saw horses
signcrafter
I've gone through a bunch of different saw horses over the years and haven't found anything I've liked. Right now I have 4 of these and they are horrible.
https://www.menards.com/main/tools/...857146263.htm?tid=-7279314539802695586&ipos=1
They looked good and felt good when bought but the folding hinges ****. The screws fall out and the hinge binds and it's just not a good saw horse.
I'd like something that folds for storage and portability and works as it should. I'm willing to spend some money on them so I get something that is strong and works good.
mark#3
I have the 'original store horse' saw horse, which is a very good 'horse'.Of course this is from a long time ago so the quality is superior to what is made today.But maybe not.Also maybe they still make them?
lardy1
I've had good luck with the folding sheet metal ones. I forget the brand name. I'm on my third set in the last forty years or so.
Chucktin
Don't forget a sacrificial cap for any saw horses.
Sent from my Pixel 4a using Tapatalk
I have two pairs of folding metal ones, one height adjustable, one not. My first pair are 20+ years old. They took a little while to break in where they would fold easily, but last time I did was a cakewalk. The new ones seemed cheesy last I looked. I have a 2x6 flat on top of the fist set, need to get one for the 2nd pair, a GS find. Will add the metal gauge later when I am up and moving.
Oops, forgot to measure. They look like these, one adjustable, one not
https://www.acmetools.com/shop/tools/allied-international-59504a
Paul_The_Builder
Dallas, TX
I have 4 of the DeWalt brand sawhorses from Home Depot, and I'm quite happy with them. They hit a good balance of foldability, durability, and sturdiness, while being lightweight and not cheap but not crazy expensive.
I used a pair of these sawhorses to hold 200lbs of Granite while I was cutting in a sink, so they're definitely sturdy.
nafterclifen
Poconos, PA
Like you, I don't have space to store a non-folding sawhorse. So I built my own (see #3 in the link below). I like them a lot but they aren't exactly light.
Collapsible Sawhorse with a Built-In Shelf
Another option, which I just purchased, is the "Hide a Horse" sawhorse. Interesting concept. They are light but also stable and sturdy. The original owner used to make a standard height (29") and tall height (34") but he sold out to Burro and they only make the standard height. If you do buy them, Home Depot has the best price. All links are below.
Original Company - https://hideahorsefoldingsawhorses.com
New Company - https://www.burrobrand.com
Home Depot - https://www.homedepot.com/p/Burro-Brand-29-in-Wooden-Folding-Burro-Sawhorse-2-Pack-FBP/313328953
signcrafter
LB-1911
Northwestern Il.
"Déjà vu all over again"
signcrafter
I thought I had already made a thread on horses but when I searched this morning nothing came up. I never did get a new pair after that last thread and forgot about posting. Thanks.
metaldad
nw indiana
i also have the menards horses.
only thing i dont like, and i havent had the time, are the sharp edges.
ill dress with a grinder, eventually
Cheepbeer
NW Ohio
I’ve got the Lowe’s brand of those, yes they’re horrible. The cheapie plastic things I’ve got are more stable.
Rinspeed
NY
I have a couple of the cheap Stanley adjustable and they are cheap but they do work.
Indexmill
Central NC
Honestly, I am amazed at how usable even a cheap plastic set is. Give it a try before over thinking it.
nafterclifen
Poconos, PA
I used plastic horses before. Junk. JUNK! Not reliable, AT ALL. Once it fails, it's done for. And it will fail. So don't even bother or waste your time. Unless all that you're going to lay on it is 1/4" round trim or something.
Ralf11
^ Bingo - I got a year out of them, waste of petroleum to make the plastic junk
Mohawk Dave
SoCal
I was a framer for many years, and I still have and love my sets.
USA Made Trojan - ...they are HEAVY.
So, I use those for heavy stuff and then I have the HF metal folding things that screw to 2x4s and those stay outside in the weather and are "disposable" but get used for lightweight work like painting stuff etc.
https://www.amazon.com/dp/B0000224RO/?tag=atomicindus08-20
BFHtime
I have always like making my own out of wood, although not collapsible. Those Trojans steel legs look great!! Foldable and strong looking. I have used some steel leg horse that were on the sloppy loose side. Also the thin steel horses tend to flex.
Downwindtracker 2
BC
I chose those folding aluminum , like guys who chose Snap-On, they are professional grade tools. For just sawing , you want something about 2' tall. A single one with a wide top, they use to be made out of 2x8s, for cutting a 2x4s. And a couple with sacrificial 2x4s for cutting plywood. I'm 6'1" with long arms and even 2' can be a stretch cross cutting plywood. I also bought two 3'ers, these are used a bench legs . I throw a piece of ply wood on them and I have bench beside what I'm working on . I can put my miter saw on it ,too
I paid $ 52.50 for the 2'ers and $75 for the 3'ers each. I consider it money extremely well spent, and I'm cheap.
GrantCee
Willamette Valley, Oregon
I've had a pair of these for about 15 years. They're wobbly until the legs are pulled out so that they're tensioned against the pair at the other end. Once done, they're pretty sturdy. I've had 1500 lbs of Hardi-Panel siding on them with no problem.
Mine didn't come drilled to attach a sacrificial 2x4 or 2x6, which struck me as odd, but easily corrected.
justanengineer
Motor City
I've had the OP set for a decade now and beat on them hard through quite a few full renos and many smaller projects without complaint. They're solid side-side when hand planing and I've had 1k lb machine parts on them several times without worry.
tube_guy
Folding or not, once you use a pair like these, you won't go back to anything else unless you're traveling with them.
Make them out of pine and they're very lightweight and really very strong. I'm sure I've had about a ton on mine, and they were extremely stable. My wife and I even used them as a staging that we would stand on to do some painting.
Dimension them right, and they are stack-able to save space.
Downwindtracker 2
BC
I love Paul Sellers, but he is an English cabinetmaker not a carpenter, This is what a sawhorse should look like https://www.finewoodworking.com/2007/01/09/build-a-classic-sawhorse
The interior cross brace is optional and the taper should start half way down the leg. When I started as carpenter, the first thing the foreman asked you to do was to make a pair of sawhorses. For some carpenters, it was their first and last day.
Chucktin
Those RK sawhorses don't look that different from the Kobalt, Dewalt, etc variety. What makes them different and superior then?
Cheepbeer
NW Ohio
I don't really know, all I did is feel one and it's not wobbly and sharp like my kobalt ones.
Chucktin
Thanks, our next trip to RK I'll check them out.
Ign
Butte Peak ND
If you want the folding sheetmetal ones, the Fulton Handy Horse is the heaviest, most robust and most rigid I've laid hands on.
Lowe's sells a variant almost as good.
The HDX ones at HD are beyond pathetic. Way too thin of material, poor design, super flimsy....just a joke all around
Chucktin
I notice most posters talk here about having a pair of sawhorses. I believe that's a mistake. You need at least 3 so that there's support for the "waste" you cut off and it (the cut off) does not pinch the saw blade, which can be dangerous.
Ign
Butte Peak ND
Ive got 2 pair these. Expensive but sturdy and made to last. They have gone up in price aLOT
https://www.fultoncorp.com/stablemate-folding-steel-sawhorse/
Amazon link
https://www.amazon.com/dp/B0009XXDIE/?tag=atomicindus08-20
Wasn't aware of their StableMate model. Looks nice but spendy as you mentioned.
The Handy Horse hovers around $50, I think I got one on Amazon for $37 shipped awhile back. Not as large as the StableMate but still of respectable quality for stamped sheetmetal
https://www.fultoncorp.com/handy-horse-galvanized-steel-folding-sawhorse/
Ign
Butte Peak ND
I rarely actually do any work on my sawhorses. They're just temporary staging areas to store stock off the ground, so I use pairs almost exclusively
slowtwitch73
Hellgate
Trojan. I got sick of building 'horses, throwing away rotten ones, storing them, etc etc.
Trojans are there when I need, out of the way when I don't. Need a 10' wide horse? No problem. Need two different heights, no problem.
