Good grease gun under $50
Dynasty
USA
Do you have a favorite grease gun under $50? I have been using a cheap Harbor Freight one, but would like something better quality. Primary use will be greasing off road UTVs and lawn care machines. Thank you.
Justind97
Ottawa, Canada
For whatever reason, I have had the worst of the worst luck with manual grease guns. First tube goes through fine. Any subsequent tubes never work. This is not good when I'm greasing my construction machines.
I made the move to the Dewalt 20v grease gun and have never looked back. Pricey, far cry from $50, but zero effort!
Jwallace1
spokane wa
i work at a Cat dealer and purchased one of the cat branded pistol grip grease guns about a year ago, the part number is 190-5622 i think they are about $40 to the general public, best i can tell its the same as an Alemite 555 which are $60 on amazon. has served me well and have had no issues with it.
thanks
RedneckWelder
The Ghetto Kingdom of Methlandia
thanks
Same here my manual grease gun is a Cat one off the rack in our showroom/parts counter. You can get them either lever or pistol grip.
Ton ton
Page County,VA
I like manual grease guns better than milwaukee or lincoln battery powered ones. I am still looking for a good manual grease gun.
Gummi Bear
Sunset, Texas
I have a Lincoln. Grandpa gave it to me when I started driving to keep up Maintainence on my truck. It was old when he gave it to me near 30 years ago. Not sure of the model
I did add a Lock-n-Lube connector to it. That saves a lot of cussing.
I went to the woods because I wished to live deliberately...
Henry David Thoreau
sberry
Brethren, Michigan
I need to thin the herd for some new ones too
I need or 4. I like a lever and a pistol, one each for red stuff and sticky black bear ****.
McFarmer
Last one I got was an unused Alemite on ebay. That’s the way to go. Something like $25. USA made.
McFarmer
That would be a lever gun or a very old NOS gun. There isn't any pistol grip grease guns currently being made in the States.
Yes, the packaging was old. There were several to choose from, most had seen some use but this one hadn’t.
BlakeTheCarGuy
Roanoke Virginia
I just have a manual one from Tractor Supply but it isn’t that good. I use my battery powered Flexzilla from Tractor Supply it works awesome it was on sale for $99 when I got it.
