andyvh1959
For the wiring in my detached garage, i ran the wires through the 2x6 wall studs. I drilled holes for the wires at least 1" into the wall from the inner face of the wall studs. Electrical inspector for Green Bay WI came by and he only noted a few thing to correct:
1. 2nd ground rod 6' from the one I have routed through the slab.
2. Wiring staples within 8" of the boxes
But he did not add that I should have metal straps on the stud guarding the area where the wires pass through the studs. I routed the wires through the wall less than 8" above the boxes purposely to reduce the likelyhood of a nail or screw into the stud hitting a wire. Does the NEC require metal guards on the studs? Or is it a regional wiring specification? I added the 2nd ground rod and stapled the wires above the boxes as noted.
