Last night I completed the last task of winterizing the lawn & garden equipment, pressure washing. I was barely able to complete before losing my light for the evening. These short days ****.
I dried everything off, hit the pivot points with some lube, hit the bare metal under the decks with a little WD-40 and parked everything back in the garage until spring.
I then moved to the next job in my white board. This one is for a local guy who needs some holes drilled in a couple of Dana 60 hubs.
A few holes were welded up to go from the standard 8 on 6.5” bolt pattern to the 5 on 150 for his Toyota.
Set up on the mill and locating center.
That was all for the evening as it was date night. Next will be to program in the bolt pattern and drill some holes and sneak up on the diameter for the knurls on the studs.
Thanks for looking.
